2025-04-01, 02:01:05
Pages: 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 ... 38
Author Topic: Don Smith Akula, Ruslan, Stalker, device discussion and replications.  (Read 68283 times)
img  Itsu
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #62 on: 2023-06-01, 09:26:18 »
I looked at my Grenade (with Inductor and antenna) using several methods / equipment to determine its resonance frequencies / harmonics.
Here i present the result using Spectrum Analyzers
I have the Inductor and Antenna around the Grenade left alone with both leads open.
I "excite" the Grenade with a coupling coil (4 turns) attached to my FG set for square wave, and measure the resulting signals using the SA probe ground lead on one of the Grenade leads and the SA probe tip connected to the insulation of the other end thus avoiding to "load" the Grenade too much with the 50 Ohm impedance of the SA, see diagram.
Results can be seen in the attached pictures, first the MDO3054 SA results, then the Rigol DSA 815 results.
The strongest response was with the FG set to 1.87MHz (1/4 wave resonance), and the generated harmonics shown are:
1.87MHz (base resonance)
5.6MHz  (3rd Harmonic)
9.33MHz (5th Harmonic)
13.1MHz (7th Harmonic)
16.8MHz (9th Harmonic, strongest)
20.5MHz (11th Harmonic)
24.3MHz (13th Harmonic)
etc.
img  NickZ
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #63 on: 2023-06-01, 13:10:17 »
   itsu:
   Ok, thanks for the info. Can you explain as you see it, just what does that tell you?
Seams like the numbers don't really match up to what Stalker mentioned.
And that makes me think that there may also be something wrong with the previous build information and device instructions, as well.
   Thanks again itsu.
« Last Edit: 2023-06-01, 14:14:48 by NickZ »
img  Itsu
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #64 on: 2023-06-01, 14:48:44 »
Nick,
well you mentioned here: https://www.overunityresearch.com/index.php?topic=4471.msg104865#msg104865 that: "Stalker mentions Grenade frequency of 15.6Mhz", so perhaps he was referring to a harmonic like my strongest 9th harmonic at 16.8MHz which does exist in the Grenade.
If this is important i do not know yet, but for now It's nice to know the grenade is generating HF over a broad spectrum.
img  Maxolous
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #65 on: 2023-06-01, 14:52:21 »
Have you tried this method of Sergey stalker.
https://youtu.be/ObQFTTJimuI
img  Maxolous
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #66 on: 2023-06-01, 15:36:31 »
If you go to your sub-harmonic, maybe You're using divide by 50 or divide by 100.
If divide by 100 , then you will have 18.7 khz.  Choose range of 18---19khz with a square wave signal. As you sweep check where your 3rd harmonic is at maximum. It could be at sub-harmonic18.5khz or same 18.7khz
Maxolous.
img  Maxolous
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #67 on: 2023-06-01, 15:42:11 »
Quote from: Itsu on 2023-06-01, 14:48:44
Nick,
The issue is 15.6 MHz I still think is a typographical error or translation error. All manners of harmonics are there and you're not going to use them.
img  Apecore
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #68 on: 2023-06-01, 15:44:24 »
Nick,
Nice to see those figures, is it possible to do another scan in DUT mode?
Inclusive ground connected.
Just to see what changes.
Grt, Ape
img  NickZ
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #69 on: 2023-06-01, 16:44:28 »
  As I had mentioned previously, my grenade's best output frequency is around 18.5KHz. That is with the complete system grounded,
Including the kacher circuit. That is the best running frequency for my 37.5m grenade, and 18.75m inductor. Tuning for best gain.
  I understand that more than a small deviation of 300KHz is enough for it not to sync. And mine does sync, but still needs something.
« Last Edit: 2023-06-01, 18:18:55 by NickZ »
img  Itsu
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #70 on: 2023-06-01, 21:39:18 »
Quote from: Maxolous on 2023-06-01, 14:52:21
Max,
i think so, some years ago, i will see if Vasik had translated this video then.
Not sure now if he (Stalker) is tuning for peaks or dips in this video.
Maxolous.
Max,
i will give it a try.
img  Itsu
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #71 on: 2023-06-01, 21:47:01 »
Quote from: Apecore on 2023-06-01, 15:44:24
Grt, Ape
Hi Ape,
not sure what you mean with "scan in DUT mode?"
But i understand you want me to look at those harmonics again, but now with a ground wire connected.
But remember that one side of the Grenade was already grounded by the Spectrum Analyzer so i don't think it will make any difference.
img  Apecore
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #72 on: 2023-06-01, 22:21:38 »
Quote from: Itsu on 2023-06-01, 21:47:01
Hi Ape,
I did understand you did a measurement in DUT... the grenade connected as it schould be?
I saw difference in grenade stand alone results and conected as built
img  Itsu
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #73 on: 2023-06-02, 09:45:37 »
Hi Ape,
with DUT i mean "Device Under Test" in this case the Grenade.
Because in some publications they call the device / component being tested this way (DUT) like here: https://www.overunityresearch.com/index.php?topic=4471.msg104868#msg104868.
Anyway, yes, there will be a difference in measurement results with the Grenade (DUT) as stand alone like i have now and when in the complete circuit.
img  Maxolous
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #74 on: 2023-06-02, 12:02:48 »
Quote from: Maxolous on 2023-06-01, 15:36:31
Maxolous.
My little correction here; "divide by 10 will be 187khz.
Maybe you will need to sweep between 180khz ---190khz , that's what I meant to say please.
img  Itsu
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #75 on: 2023-06-02, 21:25:25 »
Max,
i have found out that i indeed tried that as can be seen here:  https://www.overunityresearch.com/index.php?topic=3926.msg90914#msg90914.
The attached PDF (pp.pdf) there from Vasik contains a short translation too, so i will revisit that part / pdf once again.
By the way that thread contains a wealth of information especially due to the (translation) work of Vasik041.
Concerning your above post about "divide by 10 will be 187khz", i tried that too using my SA and the earlier used measurement setup:
https://www.overunityresearch.com/index.php?topic=4471.msg104955#msg104955.
At 187Khz square wave carrier frequency we see these harmonics:
So the carrier frequency of 187kHz shows as a low amplitude peak with increasing amplitudes (odd) harmonics peaking at the 9th harmonic at 1.693MHz, so the 10th (even) harmonic does not exist.
EDITED the 1.69MHZ peak to be the 9th harmonic, not the 11th.
« Last Edit: 2023-06-03, 20:01:43 by Itsu »
img  Maxolous
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #76 on: 2023-06-02, 22:58:50 »
Quote from: Itsu on 2023-06-02, 21:25:25
Max,
So the carrier frequency of 187kHz shows as a low amplitude peak with increasing amplitudes (odd) harmonics peaking at the 11th harmonic at 1.693MHz, so the 10th (even) harmonic does not exist.
Nice work Itsu.
img  Maxolous
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #77 on: 2023-06-03, 11:58:16 »
The 1.693 MHZ might be best for you
img  Centraflow
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #78 on: 2023-06-03, 17:28:26 »
The only way to find the Fr of these coils is like the attached, IMO.
img  forest
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #79 on: 2023-06-03, 19:28:10 »
May I ask : why so many coil layers ? Was it explained ?
img  Itsu
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #80 on: 2023-06-03, 19:58:48 »
Quote from: Maxolous on 2023-06-03, 11:58:16
Max,
well that depends, as i still think the 1/4 wave resonance of this coil is at 1.879MHz and the above harmonics only shows odd harmonics due to me using a symmetrical (50% duty cycle) waveform.
This changes if i reduce the duty cycle from 50% to 36% (something stalker promoted too by setting the push-pull duty cycle to 33% if i recall correctly).
Then still with my 187kHz carrier frequency, the SA shows both odd and even harmonics, including the 10th harmonics at 1.88MHz (had to reduce the max. frequency to 2.5MHz), see:
img  Itsu
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #81 on: 2023-06-03, 21:39:08 »
Quote from: Centraflow on 2023-06-03, 17:28:26
Mike,
if i do that, i get the following screenshot (i reduced the sweeping range to 10MHz (from your 50) as we primarily want to know this lower frequency range only):
So each horizontal division is 1MHz (starting from 1kHz) so we see a big resonance peak at 1.8MHz and going left a smaller peak around 600kHz so rather similar with what we have seen using the VNA and SA (1/4 Wave resonance at 1.879MHz)
Using a 10s sweep.
img  Centraflow
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #82 on: 2023-06-04, 08:05:11 »
Well that confirms the Fr. Does that coil normally have a ground running through the centre? If so then it will form a multi wave at that frequency, like a vibrator.
img  Itsu
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #83 on: 2023-06-04, 09:36:33 »
Mike,
no, the hot end is running through its center.
img  Centraflow
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #84 on: 2023-06-04, 09:50:44 »
Quote from: Itsu on 2023-06-04, 09:36:33
Mike,
Interesting, and it was like that when you did that sweep? That must be why it is what I call "fuzzy" pulses.
« Last Edit: 2023-06-05, 18:55:01 by Centraflow »
img  Itsu
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #85 on: 2023-06-04, 12:00:59 »
img  Itsu
Quote from: Centraflow on 2023-06-04, 09:50:44
Interesting, and it was like that when you did that sweep? That must be why it is what I call "fuzy" pulses.
Yes, see this picture of my Grenade:  https://www.overunityresearch.com/index.php?topic=4471.msg104788#msg104788
The thick left part is the hot end, and the both leads come out on the right side.
The "fuzzy" pulses i think are more due to the low amplitude (due to the 10Meg series resistor).
img  Itsu
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #86 on: 2023-06-04, 12:03:32 »
Quote from: forest on 2023-06-03, 19:28:10
Hi Forest,
i don't know, it was like that from the beginning, some say to get a low inductance, some say to get multiple standing waves or resonance peaks, but its anyones guess i think.
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-04-01, 02:01:05
