2025-03-31, 23:27:25
Pages: 1 2 [3]
Author Topic: Links and Docs  (Read 12430 times)
Some interesting reading from Mr. Gorchilin
http://gorchilin.com/articles/radiant/second_magnetic_field_amplifier?lang=en
HGi Vasic & thanks for the pointer, while we are on that device, over on the right side is a push pull driven by a TL494 via a series tank driver into an air coil coupled to another coil, It looked interesting and I have made an air device and tested it with a TL494 my 494 i'm luck if it will go up to 600khz thus having no efect on the air coil if io drive it with a SigGen it likes 5mhz, 5 mhz could be a harmonic of the 1Mhz osc x4 or 5.6 Mhz if the 1000 khz & 400khz are added it could be the 4th harmonic, any ideas ?
If you talking about this circuit
Recommended frequency up to 300khz
but it will work on higher frequencies
see https://www.ti.com/lit/ds/symlink/tl494.pdf?ts=1646436249478&ref_url=https%253A%252F%252Fwww.google.com%252F
-Vasik
-Vasik
Hi Vasik err no  I was thinking more on this section
Why do you think that "green coil" resonate at 5Mhz ?
Simple answer because I have wound one and it with a Sigl gen and scope it peeks at about 5 mhz
if i try to tune it with a variable cap it starts to attenuate and cuts off at about 100 khz
Sure i can put caps across it to tune it but what to  in frequency ?
« Last Edit: 2022-03-06, 11:07:40 by AlienGrey »
L2 + L3 tuned with C1 to 20khz resonance
have you checked that it works?
I see this as a clamping circuit only.
No, I haven't tried this.
Many people reported interesting effects from flat coil, so I thought that this will be interesting.
-Vasik
here is scope shot at 20khz SYNTHESIZED with actual green coil and Sig Gen
The coil here has such a huge bandwidth any freq can be selected with the right cap.
Out of interest has any one got a device like this COMPLETED and working?
This is continuation of the https://www.overunityresearch.com/index.php?topic=4216.msg97141#msg97141
I am fascinated with this device simplicity and author's genius.
Here a transcripts for other videos from Dmitri's channel, please see how
device was developed from idea to prototype.
-Vasik  :-X
Transcript for Akula's video about fuel reactor
Transcript for video called Proper pulse from igorek30.
This was a gift to FE researchers for the New Year 2019.
(Just 3 months later Igorek left us)
PS I intend keep threads closed for some time to avoid unnecessary escalation.
PM me if you want say something.
« Last Edit: 2022-05-16, 19:29:37 by Vasik041 »
Schematic for Mobylizer's device mentioned in above video
Pages: 1 2 [3]
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-03-31, 23:27:25
