This is the first post in quite some time, I have not been well, and still nowhere near 100%.
Because I left my group hanging in mid-air, I have decided to go directly to the end and post the attached. This will effectively remove any obligations that were in place, I thank you for your patience.
What is attached is a prior art declaration which was made back in 2021 and filed. The form of it is a patent application, and there is a good reason for this which I will not go into here.
Anybody can use this, but nobody can patent or claim it as theirs. You will see that it is "a new component" that is claimed, STEAP capacitor.
This is the component that is needed to extract and add atmospheric charge. It is simple but complicated in its workings, but basically, it uses charge displacement and balancing to extract charge and then deliver this charge within a cycle, it is both frequency and duty sensitive.
I will give no more explanation, I will leave this up to you to find this for yourself. The included typical circuit is correct, but you will have to make your own method of control of the C3 voltage, the resistor is an example of control. A resistor would work for fixed output, but you would probably blow a lot of Mosfets before you found the right value, you are forwarned.
I am moving on to a new project as and when I am fit enough.
Mike N.
"All truth passes through three stages. First, it is ridiculed, second it is violently opposed, and third, it is accepted as self-evident." Arthur Schopenhauer, Philosopher, 1788-1860
