2024-11-26, 06:29:41
Author Topic: Documentation  (Read 9151 times)
Main topic got now more than 45 pages. I will collect here all relevant documents about RuslanK device.
The idea is to have a place where files can be easily found.
Please refrain from discussion here, do it here https://www.overunityresearch.com/index.php?topic=3926.new;topicseen#new instead.
Vasik
Replication of Roman Karnoukhov’s (Akula) device by Sergei Stalker (translation rev.3)
Contents
  • Introduction
  • Controller for FE generator
  • Controller for Tesla Transformer
  • Controlled kacher
  • General diagram of the device
  • Device schematics
  • Push-pull schematic and tuning
  • Resonator coil (grenade)
  • ¼ wave resonance
  • Pulse amplifier schematic
  • Work of controlled Tesla coil, preliminary tuning
  • DC-DC converter for Tesla coil or kacher
How RuslanK’s device work
- short explanation by Sergey Stalker
Current sensor tuning
Testing gradient coil and selecting proper push pull frequency
Choosing Tesla coil frequency
« Last Edit: 2021-07-10, 20:01:27 by Vasik041 »
Pulse amplifier for signal generator
Tuning checklist
 all parameters known about Sergei’s device collected in one place
Gradient coil variants and calculator
PCB board with kacher
Notes:
- U10 pin 1 and 7 should be switched as it shown on s1_rev2.pdf
- recommended add 0.1uF from U1 pin 4 to ground
- recommended add 1K from U1 pin 3 to ground
- recommender use 470ohm in series with 10k pot as R17
My current understanding is that Q3,Q5, R11,R14,R15,R16 can be omitted, just supply +15V to D1 anode instead
Bump...
« Last Edit: 2021-07-10, 17:00:59 by szaxx »
Coils name guide - see pictures
Notes
1. kacher = tesla coil with one transistor driver circuit
2. primary coil often called "inductor"
3. greande often called gradient coil
Coil's numbering
Yoke primaries: L1a and L1b
yoke secondary 1: L2 (25 / 18 turns)
yoke secondary 2: L3 (3 turns)
(Grenade’s) Inductor: L4
Grenade: L5
Kacher primary: L6
Kacher secondary: L7
Shniaga: L8a,b
Antenna coil: L9
Power filter: L10a,b
Push pull trafo (yoke) reference data, Itsu's variant
* yoke diameter is 12 cm (wide part) by 7cm (small part)
* cross section its about 5cm long and 0.8cm thick, which makes it roughly 4cm²
* gap approx. 0.1mm
L1a, L1b 8 turns each 42uH @ 10KHz.
L2 18 turns 124uH @ 10KHz.
L3 5 turn coil  13.5uH @ 10KHz
video https://www.youtube.com/watch?v=DSy4wE09H-U
« Last Edit: 2021-07-10, 21:02:30 by Vasik041 »
Gradient coil reference data, Itsu's variant #2, Vasik's variant #1
4mm² wire, it measures (caliper) 4.2mm outer diameter and 2.5mm core diameter, so insulation is 0.85mm.
Wire type: H07V-K4 BLUE/RED
Doing some calculations with that data and.....37.5m
Length: 37.5m
combined resonance frequency: 3.05MHz
induction: 143uH
nbr turns: 220
single coil out of the 37.5m of 4mm² wire and it measures 137.5uH @ 100KHz and has 214 turns, so reasonably close to the calculator.
Push pull trafo reference data, Vasik's variant
E70/32 N87 core, gap approx. 0.5mm
wire 60x0.1
L1a,b 10 turns 110uH
L2 25 turns 2.5mH
L3 4 turns 4uH
Vasik,
Can you provide the brand and part number for the wire you used (ie, Lapp 4520013, etc)?
PW
PW,
H07V-K4 RED, see attached PDF
I think it is more or less standard.
Vasik
PS Itsu use helukabel h07v-k 1x4mm2  nr: 29163, see:  https://www.tme.eu/en/details/h07vk400bl/single-core-cable-strand/helukabel/29163/
« Last Edit: 2021-07-14, 19:53:26 by Vasik041 »
This is specially for those who want to know where energy comes from ;)
https://www.youtube.com/watch?v=bBp_SPJAOJc
"pigs don't fly, unless you throw them out of airplane, then they do"
Gents please be aware this section of the thread is for Technical documentation Only.
Please post your other thread related posts on the main thread.
@ ‘Dally, Shark & Ruslan workbench’.
As unrelated posts, and (trolling and social manipulation,) will be deleted.
Many thanks Sil
« Last Edit: 2021-10-24, 13:53:25 by AlienGrey »
Good Day to All,
1 of 3
These next three post summarize, to a great extent, the detailed operation of a RUSLAN Type Generator.
This post (#1) contains a portable data format (pdf) attachment of two schematics:
On page 1. is FUNCTIONAL SCHEMATIC - RUSLAN TYPE GENERATOR by Absolute, and on page 2. is FUNCTIONAL SCHEMATIC - RUSLAN TYPE GENERATOR ADAPTED FOR STAN MEYER DEVICE also by Absolute
These, along with schematic diagrams found in the next post attachment, [02 Generator 4KW - Demo in Forest - analysis - 14Nov21f.pdf] provide good reference material for studying the Ruslan Type Generator.
SL
Attachment:  01 RUSLAN - Absolute - Functional Schem 14Nov21f.pdf   3,875 KB
Good Day to All,
2 of 3
NOTE: If you do not have a good grasp of the detailed operation of the Ruslan type devices, or you just need a refresher, this document is for you!
This post (#2) contains a portable data format (pdf) attachment [02 Generator 4KW - Demo in Forest - analysis - 14Nov21f.pdf].  The document is only 27 pages but has been subjected to a great deal of discussion and vetting by those skilled in the art.
The document has evolved over several years (origination was around the 8th of December 2016). Many updates occured as an understanding of the various elements and interactions were discovered. Two lingering pieces of operation theory remained elusive until recently:
First; where does the excess energy come from?
Second; how is the high voltage Tesla or Katcher related to the overall operation; is it energy related and how does it transfer to the energy removal coil?
Areas within this document where these queries arise are in Purple Type, while brief answers to these questions are in Blue Type.
Following a peer review (now in circulation) of the above new discoveries is finished a new, integrated, document will be prepared and presented outlining this type of EE generator; including complete CAE analysis, spice schematics and CAD assembly information.
This Project and it's Documentation are ongoing "Works in Progress" and change often.
SL
Attachment:   02 Generator 4KW - Demo in Forest - analysis - 14Nov21f.pdf  1,393 KB
Good Day to All,
3 of 3
This post (#3) contains a portable data format (pdf) attachment [03 NOTES Inverter-Generator-Proj 1_14Nov21f.pdf].
It describes one of many methods that can be used to condition the output from a RUSLAN Type Generator to provide a means of powering conventional AC or DC appliances. Many advantages are gained using this approach when fielding an Excess Energy Generator.
These 3 posts cover in detail at least one version of the Ruslan generator and are of  great value in understanding and developing these, and future, devices.
SL
Attachment:  03 NOTES Inverter-Generator-Proj 1_14Nov21f.pdf   769 KB
Good Day to All,
1 of 1 - Schematics and drawings (109 total). Information - may also be useful for reference or just review.
Compressed using "Caesium" (freeware) at a quality of 6% (6/100) so some may be hard to read. If you need a higher quality and can not otherwise find the original (some date back to 2014) post the title.
One viewer many people use is "IrfanView" (freeware) it's excellent, fast and versatile.
SL
Attachment:   __SCH_ALL_Comp.zip  3,539 KB
RE: Reply #19 on 2021-11-16, 04:05:10 above: ("2 of 3")
(https://www.overunityresearch.com/index.php?PHPSESSID=5gvrm67i0upmb6a842fdnsd3v6&topic=4154.msg96061#msg96061)
NOTE: Conclusions [in Blue type] regarding (1.) "First; where does the excess energy come from?" and (2.) "Second; how is the high voltage Tesla or Katcher related to the overall operation; is it energy related and how does it transfer to the energy removal coil?" now appear to be pre-mature, and may not be fully correct or complete.
Our appologies for any inconvience or problems this "optimistic conclusion" may have caused. As outlined in Reply #2502 below:
 (https://www.overunityresearch.com/index.php?topic=3926.msg96225#msg96225)
Dissappointing Results
With deep remorse we must now be conclude that sustained Overunity, FE, CE (or what ever you want to call it) is extremely unlikely from any Dally, Shark, Ruslan type device.
Extensive investigation and analysis of a variety of these apparatus has not uncovered any means by which this excess energy phenomenon can be sustained. This conclusion is also supported by years of failed reproduction attempts done by scores of developers and researchers and considerable, extensive, internal work.
Our latest batch of detailed CAE runs were inconclusive at best.
With sadness and disappointment we now conclude our search. We hoped that we were wrong; but our efforts must come to an end.
Best of luck to all.
SL
Again, sorry to have "jumped-the-gun", best regards,
SL
The Ultimate Speed - An Exploration with High Energy Electrons
Summary
These two questions have appeared time and again in excess energy discussions as far back as the subject itself.
 1. Where does the excess energy come from?
 2. How does this excess energy couple into a system like the Kapanadze or Ruslan scheme?
SL
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2024-11-26, 06:29:41
