I think it is important to measure one of your non-ferrous strips or wires to compare. Agreed. I'll update this post with the relevant results when the opportunity arises. And yes, such short lengths of wire are indeed close to bottom-scale for the meter I'm using. I hope others are picking up some nickel strip so they can tinker around themselves as well  Update 4/28: (Meter short-circuit calibrated before each measurement) Test using 100in nickel strip: 2.7uH (@1k) .257 ohm measured resistance .254 ohm measured impedance @1k Test using 100in paired copper speaker wire (~14awg) 2.6uH (@1k) 0.033 ohm measured resistance 0.023 ohm measured impedance @1k Note: measuring permeability, specifically change in permeability requires a different setup entirely.
« Last Edit: 2021-04-28, 17:39:09 by Reiyuki »
