Hi Mike, it's not that I'm being deliberately negative here, I'm just being my usual cautionary self, ie non-trusting and sceptical!
I'm quite familiar with the history of the common-duct electrolyser. I've been playing with this stuff for a good few years now and in fact I used to be in regular email contact with William Rhodes himself.
What is not clear from Eckmans paper is how the 'Brown's Gas' he analysed was produced. I mean are we to assume that the resulting gases are the same from a straight dc common-duct electrolyser as they are from an equivalent pulsed system? Is he simply assuming that any common-duct electrolyser produces 'Brown's Gas'?
I've just re-read the paper, and though initially it reads well and very scientific, every time I see new things that put me on edge. This for example:
Linear water isotope... what? This makes no sense to me whatsoever, as an isotope is an atom with more or less neutrons - more or less electrons would simply make it an ion. Why would he call it an isotope? I think they should propose something else!
And another thing that is really bugging me is where are all these electrons supposed to be coming from to provide water molecules with additional electrons? If this was happening to any great degree, the current through the cell would be seen to diminish. Electrons from the cathode that are needed to maintain the ionic current flow through the cell in order to produce hydrogen and oxygen in the first place!
I daresay most people merrily skim through Eckmans paper without fully understanding the implications of what is being said, and so are without any concerns or questions... but I have a list of questions as long as my arm! To my mind a lot of what Eckman states simply does not sit right with me. Hence, as scientific as it may seem, I'm extremely wary of this paper.
Hi Farrad,
It looks to me that Eckman got his Brown's Gas from one of
George Wiseman Brown's Gas "welder units", for two reasons, first because he quotes George, and second because he lives in the same area as George. You can try calling or emailing Chris and ask specifically. I emailed Chris months ago without response to date, although I was not expecting a reply anyway.
There are not a lot of Brown's Gas units out there and since Chris is young and has chosen to research a famous "non-conventional energy technology," and has an "open mind" to discover/research new technologies, it looked to me that George might have even guided and asked Chris to do this analysis. This is all conjecture on my part but does seems to fit the facts.
In any event, the Brown's gas that Chris analyzed looked about right for a typical common ducted system, through my mind.
Your next question on "...where are all these electrons supposed to be coming from to provide water molecules with additional electrons?"
My answer:
The electrons are coming from the DC power supply through electrode plates themselves, and here is why. The
Rydberg cluster theory states that not all of the Brown's Gas electrolysis input DC power is in splitting 100% the water molecule completely into hydrogen & oxygen, but that a good percentage of the electrons instead binds to form the Rydberg water clusters. The gas spectrometer proves this out.
Mookie's Electrolyser Accelerator
The 3rd highest amount of atoms and molecules are what Chris calls
"Plasma Expanded Water" .
So as we can see, there are a lot of other atoms and molecules inside the Brown's Gas. This findings goes counter to the "Conventional Brown's Gas/HHO theory" which states, that it is a 100% mixture of hydrogen, oxygen in atomic or diatomic forms, or in para or ortho states. If Chris was using George's Brown's Gas, his generators are the most energy efficient electrolyzer generators one can buy "off the shelf" today.
In the graph above, the diatomic hydrogen came in second place, and the monatomic oxygen and hydrogen, were way down the list.
I am sure that if you analyzed a
Bob Boyce 101 plate cell, there would be more percentage of monatomic hydrogen & oxygen, but there are only a handful of units out there in the real world. What is needed is more experiments, data and analysis from the different Brown's Gases researchers units being built and discovered daily.
For example,
Fast Freddy ran his truck off his small tube cell unit in the truck bed. That design I would like to see the gas spectrometer readings on. I plan on building a unit.
http://www.futureenergyconceptsinc.com/product/hydrogen-hogAnother electrolyzer design that I am currently building is based on
Zach West's spiral coil electrolyzer plates design.
http://www.free-energy-info.co.uk/ZachWest.pdfWest's design is very similar to Freddy's design where there are lots of electrode plate area that all fits inside a large GE water filter housing A special PWM will be pulsing the 2 plate electrodes with high voltage (12V DC) and high amperages (250 amps), to 60 psi cell pressure. That 1/2" thick walled GE house water filter is rated to 120 psi.
http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=GXWH40LMike
