2025-04-01, 04:45:51
Author Topic: Interwinding Capacitance H Field  (Read 9974 times)
This will be a study and analysis of an inter-winding capacitance generated H field and it's applications for possible OU.
This subject was initially discussed on Smudge's thread "Smudge proposed NMR experiment replication" and moved here for further analysis.
The schematic below represents the apparent two H fields present in a pair of identical flat coils separated by a given distance and driven in a bucking mode.
The pix shows the test device used and the scope pix shows the waveforms obtained.  CH1(yel) is the input from a Rigol SG with a 50 ohm source, CH2(blu) in the open circuit voltage for the solenoid coil, and CH4(grn) is the current in the single turn loop.
The focus of this thread will be the voltage generated in the solenoid by the H field produced by the inter-winding capacitance.  There is also a second H field generated by each bucking coil that induces current in the 1 turn sense loop but that is left for another time.
PM,  O0
Yes for me it is the changing electric field within the capacitance creating the magnetic field as you know I am working on that field when you create harmonic resonance within that field.
Great thread, will be watching with interest.
Best regards
« Last Edit: 2020-07-27, 13:54:44 by Centraflow »
PM,  O0
Best regards
Hi Mike,
Yes, this could get interesting!  I did think of your recent projects as I was "getting" this so we'll see where it goes!
All,
I removed this post due to a gross error and will re-post when corrected!
« Last Edit: 2020-07-27, 20:34:42 by partzman »
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-04-01, 04:45:51
