2025-04-10, 21:35:37
Pages: 1 [2]
Author Topic: PHOTONS AND PHONONS OPEN DISCUSSION  (Read 4803 times)
...I find it curious at which the angles of rotation where the pattern shifts and believe it warrants further experimentation.
This is the angle when the interferometer mirrors would be distorted by gravity the most and change the optical path length the most. They become horizontal at that angle of the bar.
I am sticking with Photons atm even though it seems low-frequency photons do not have the energy of high-frequency Photons, but I think that can alter through harmonic addition.
Photonic harmonics I am going for low-frequency Photon acceleration by 3rd harmonic generation in an electromagnetic loop generator, "sounds good but does it work" I believe it does because if it can be done with light waves why can't it be done at lower frequency waves!!
I have shown this in the past using 3 harmonic related frequencies adding.
More to come
The following I have talked about before and those who have had access to my work know this, but I think that the significance had been missed.
Triplen Harmonics – The triplen harmonics are defined as the odd multiples of the 3rd harmonic (ex. 3rd, 9th, 15th, 21st etc.). Triplen harmonics are of particular concern because they are zero sequence harmonics, unlike the fundamental, which is positive sequence. The consequence of this fact is that the magnitude of these currents on the 3 phases are additive in the neutral. This can lead to very large currents circulating in the neutral, and unless the neutral is sufficiently oversized this can present a fire hazard.
This is normally a very big problem in the power industry but here it is put to use. The huge currents formed in the neutral of a 3 phase system can be destructive, but what if they are put to use, what if by design the 3rd, 9th 15th, etc are fabricated in a never-ending loop creating high frequencies. The fundamental could be 5kHz but the overall bandwidth could be huge, but how can the energy be extracted? well this will slowly become clear, but where does this energy come from if the system self feeds. This is one reason why I started this thread, under COE this is not possible and the energy has to come from a reaction with existing energy, is this energy photonic? is the sea of energy around us photonic? what was it that Tesla said! tap into the existing wheelwork of the universe.
Now maybe you will see where I am coming from.
regards
There's no mechanism for getting out more than you originally put in.
To tap into the wheel-work of the universe, try coupling to the natural rotation of particles.
Photons!!!!!!!!!!
Grumpy:-
A mechanism for extracting the energy! that has been the problem if we don't know where that energy is coming from and in what form.
Taking the classical view that electric fields and magnetic fields are made up of photons we can start to postulate that either the magnetic field of the Earth or the electric field between the Earth and Ionosphere is where energy can be extracted 24hrs a day, I am going to put my money on the latter.
Below is a schematic of a first phase of what will be a three phase circuit which will generate Triplens by design from a modestly low frequency input of around 5kHz. It should be noticed that this is of a class E design (zero switching). Note:-C2 is not required if no other phases are connected.
Where does the discharge from the choke go when the mosfet switches off?
I hope that this will save you a lot of time and frustration:
Energy exist everywhere and can be harnessed everywhere without need to tap into the "earth" at all.
The discharge from the choke just dissipates as the magnetic field collapses.
Unquote:
The magnetic field collapses yes but it does not just dissipate into thin air, it is collected in the capacitance between the coil and ground and as there is no diode to stop feedback it will go into oscillation at the resonant frequency of the capacitance and coil until the next pulse of the mosfet.
Now if the capacitance and coil (LC) are designed for the 3rd harmonic of the mosfet frequency the clock will modulate the 3rd harmonic frequency (5kHz modulator of 15kHz carrier). Now you add in two other stages each 120º phase difference and you then have the full TRIPLEN effect charging and oscillating between the 3 plate capacitance and the inductance of the coils (stepped inductance).
I am sticking with Photons atm...
But do you know what a photon is ? ...not only how it behaves
Well explain to me what they are
Let's look at Phonons.
Phonons vibrate, phonons are the quantized descriptions of lattice vibration. Atoms in real space vibrate. Phonons, reciprocal space descriptions or waves if you want to call it that, propagate. What causes the lattice/atoms to vibrate? Temperature. At any temperature above 0ºK (and technically, even at 0ºK,Quantum zero-point fluctuations.)  atoms will be vibrating about their equilibrium lattice positions.
Higher the temperature, the more vigorous the vibration. The interaction between the atoms will decide how much the phonons can propagate before scattering. Now if the potential well is harmonic then you essentially will have an infinite mean free path or consequently an infinite conductivity.
Test post
https://youtu.be/P6KJ0JHfXlM
 for those who have not seen this.
Attached goes with the video.
Sorry that the RF affects the camera
« Last Edit: 2020-07-20, 15:06:35 by Centraflow »
Pages: 1 [2]
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-04-10, 21:35:37
