Still restraining myself but I couldn't let this one go.
I see 5V average DC level. Is that higher than the VCC ?
What you call Vcc in this context ?
My example illustrating abstract idea of the transients, not directly attempting simulate Itsu's circuit.
It is the high level of the step stimulus that stimulates the underdamped LCR transient.In Itsu's case that would be the 24VDC.I know.Perhaps the inclusion of the effect of the diodes (incl. MOSFET's body diode) would illustrate the ratcheting of the average DC level.
First show what happen when we use short pulse burst. I guess everyone saw it already on the scope.
And second show what happen when... frequency of pulses in the burst does not match LC frequency.
In other words, I agree with your assessment of the AC behavior but the jury is still out on DC levels of the steady states, which occur between bursts.In Itsu's scopeshot he marks these steady state levels with 90V, 120V, 150V.
I think that this DC is a MOSFET capacitance charged thru diode.
Why doesn't this capacitance get discharged when the MOSFET shorts its drain and source ?
Not sure this is what you mean by "larger scale (horizontally) snapshot", but this is one of the first burst of pulses after attaching 24V to the primary kacher coil (single shot).We see the 3 first pulses (out of 5) and after each pulse we see a steady increase in steady state amplitude/ringing and after all 5 pulses we see an increased steady state (90, 120, 150V).By the way, the ringing peaks between the pulses are 88ns meaning a frequency of 11.3MHz pointing to the resonance frequency of the primary kacher coil i guess.Itsu
I was testing the new pulsed MOSFET kacher with 24V on the primary kacher coil / drain.While monitoring the drain using the yellow probe, i noticed that directly after starting to put 24V on the drain / primary kacher coil, i see way more then 24V on the drain, see screenshot 1It shows that withing a few cycles the drain / prim. kacher coil voltage raised from 90 to 120 to 150V.Screenshot 2 shows an expanded view of one of the drain / prim coil pulses and also there we see the drain voltage go from 150V to zero.Where does this voltage come from?I used a cmc and some ceramic / electrolytic caps in the 24V supply line to the prim. kacher coil.The diagram below shows the general setup including some component modifications.Itsu
Please zoom it so the 3 steady states, which occur after the bursts of 5 pulses are in view. No more than 3 s.s., please.
So, the 24v power supply is connected to the circuit through the CMC? If so, the power supply is floating from the grounded circuit at the operating frequency due to the inductance of the CMC.You can check to see if this is creating the voltage rise on the drain by individually measuring the negative and positive terminals of the 24v supply with the scope ground placed on the circuit ground.Regards,Pm
Something like this:
So could it be the electrolytic capacitor being pumped up?
I have a question what is the procedure of tuning grenade and inductor, I know its somewher in the 63 pages but don`t recall any more where precise .
Perhaps this will be of help.
At 100V supply, 0,25A i have the following scope screen pictures and about 7,5mm streamer to a screwdriver i have in my hand.The blank copper end from the antenna is about 1,6cm long.I have a question what is the procedure of tuning grenade and inductor, I know its somewher in the 63 pages but don`t recall any more where precise .. I also want to tune resonance frequency of both.Purple trace is signal from gate Mosfet
PM,Yes.So you mean like in the below diagram, the CMC will cause the 24V to be floating compared to the negative (-) of the rest of the circuit?Even though the negatives are connected see blue in diagram?Itsu
Check it out. Stick a voltmeter on it.
OK, what might be interesting to know now is what direction the current flows into and out of the 47ufd-400v 'lytic! With the negative side of the CMC shorted, which direction does the current flow on the 24v power supply side of this cap? Hopefully this measurement is convenient!Pm
Just one thing from your previous scope traces, you have Tesla coil working on both half periods of push pull.I think you need switch one off, so it will look more like thishttps://youtu.be/Z-UaulS9EUA?list=PLK7gxeQv5qT44ZM5TVnBW534ogPJnrXjg&t=80Vasik
