What are these alternating bright and dark rings in fluorescent lamp?
Well since you can get this type of effect at off the grid powered dying tubes (burnt out or high resistant heaters) the ionising effect from the high voltage EMP effect
I would have thought using this type of device would be of little or no use to use here.
To get a more accurate reading use an inductor with two LEDs and a resister or a small neon on a plastic knitting needle and pass it down the centre
of the tube where the magnetic field is greatest.
Also grenade windings and frequency.
Lets look at how the grenade is wound, from the top we have what looks like a ¼ wave
Winding (lets suppose it’s a 41.64 wire length in all, if we divide this by 14 we get a ¼ wave
Winding length) and since its wound on a 50mm tube with a width of 42 cm wide for the
Full wave then a ¼ wave would be 11cm.
So would you expect the ¼ frequency be related to ¼ wave coil width or the actual wire length
used in that ¼ wave winding ?
Also point99
Re your statement on members IQ on this subject, have you any idea how many techniques are actually used in the construction of one of these devices ?
1 high frequency phasing of the Tesla coil ect
2 interruption of the wave and type of wave
3 modulation of the wave and technique
4 many other techniques I have not mentioned like resonance, phase locking
5 type of wave forms used in different places ect, ect
Just to name a few of the technique I have noticed I’m sure you have and others have
Noticed this in many of the designs
SIL
