Max some interesting ideaa you hav, so let me re cooperate what your sugesting.
You say your Katcher resonates at 1.2mhz, and so does your Grenade. Then you have your push pull running at 1/50 of that frequency. so if I subtract that from the 1.2mhz or whatever what frequency do I get ? Also how are you locking the 2 frequencys ?
One has to ask is your device actuly producing energy at the output ?
In case I have it wrong can you draw a block diagram and please label it ?
Many thanks Sil
@Aliengrey, The data you gave above is that of Itsu. However, for the system to function very well there must be a match. The resonance freq. of grenade must match that of Tesla. This is in order for maximum power Transfer at less input. I did mention push-pull frequency, oh yes, Itsu is right for saying that the push-pull frequency is 2% of grenade. That is to say ยน/50 of grenade. I want you to visualize it in this regard; in every one cycle of push-pull frequency, b/w you have 50 cycle of that of grenade. By so doing harmonic distortion is minimised to a large degree. It couldn't be any other way, the system is a match, match system. But it must not only be 2% , it could be 3% in as much is within the Golden rule of 30khz maximum for push-pull freq. You know I said I was building one then I stopped due to time factor. The major set back I had was my first two layer of my grenade cemented together as a result of heat and I couldn't separate them. Actually, I lit 2bulbs which were available at that time. I will try to give block diagram, mind you it's not different from the one you are use to Regards Maxolous
