Vasik: Yes, I have also made my Kacher run off of the 28t coil. That is, after being rectified, filtered, and back into the Kacher input. Yet, Ruslan said that the Kacher does not need to be very strong. Geo thinks that the stronger the Kacher is, the more output will be seen. I get that the PP is not supposed to run the load. But, it does. Yet, on Geo's device, the PP won't run, unless the Kacher is also on. Not so on mine. Vasik, I recommend that you install a ferrite rod, as the one found in the old radios. As without it your Kacher signal will be weak. Otherwise, nice going with your replication. NickZ PS. Alien Grey: Seems that you have a problem with seeing, but not believing, that the simple kacher has been shown to work, and allows the device to self run, by three different people. Adrian probably paid with his life, for what he is showing. Fakes, you say... Or is it that you enjoy being a pain in the... While you are showing nothing, for years, and years, and only to bitch at me, whenever you can. Thanks buddy. Open your eyes... Adrian Guska: https://youtu.be/zbXs0V18fkI
« Last Edit: 2021-07-04, 17:05:57 by NickZ »
