I used 2 ferrite beads (the 6 holes ones) with 1 turn each at the output (adding to the cmc) and gained only -0.5dB or so @ 4MHz, no gain at higher frequency seen.
Then moved both to the input (adding to the cmc), and gained -1dB @ 4Mhz, and also no gain at higher frequency seen (-55dB @ 10MHz).
Also adding some small ferrite toroids (od 7mm) used like beads (½ turn) does not add anything.
SC shows besides the 2 cmc's on in- and output, also the 1 turn ferrite beads on input and the ½ turn toroids on output.
« Last Edit: 2021-02-20, 20:42:11 by Itsu »
