Well, if this a naked coil, than that path should be the intrawiring capacitance (parallel capacitance).
If any magnetic field is generated by this current i doubt it as that's normally done by inductance.
Finished attempt 2 of a weave 1 pancake coil.Not very happy still with it, as the problem is to fixate it.Anyway, its specifications:OD: 119mmID: 87mmWinding: 1 layer, 10 turns of 1.6mm Litz wire (120 strand), 3.5m long, antiradial weave 1.Inductance: 17.6µH (@100kHz)DC resistance: ~0.1Ω itsu
It might be worth saying that in my experiments with transmission lines and 90 degree placed coils, the toroid winding in the NMR device will appear as a single turn to the flat coils under the right conditions.
When putting them in series (no matter how aiding or bucking), i have 34.7uH.
Toroidal coil measured earlier: 242 turns of 1mm wire, measuring 31uH @ 100Khz and 0.3 Ohm.
1 layer, spaced closely together (inside touching, outside some space)
But i see a problem with the pancake coils inductance, the selfresonance is already below 4Mhz, so if we need 4.2Mhz as NMR frequency that's not going to work.
well, if current flowing in a capacitor generates a magnetic field but in a different direction, then beforeSRF we have 100% current flowing in the coil's wires, at SRF 50% in each because of these different directions andafter SRF 100% current flowing in the intrawinding capacitance.
What wave ?I'll get back to that.
See picture:
...the toroid winding in the NMR device will appear as a single turn to the flat coils under the right conditions.
That "under the right conditions" sounds like that it is a good thing that the toroid winding in the NMR device will appear as a single turn to the flat coils, but i guess its not.
So we need a weave 1 like scheme for the toriodal coil too to kill that effect.
Some pictures from the setup using the new weave 1 pancake coils.
The schematic is next showing the fields as I propose them to exist. There are two simultaneous H fields present according to the experimental results IMO.
Yes, a current flowing through capacitance will generate a second H-field.There is capacitance between the turns of one coil (intrawinding capacitance*) as well as capacitance between the coils themselves (interwinding capacitance). All of them generate their own H-fields.Could you amend your drawing to depict the entire electric circuit, which is made by the current flowing through that interwinding capacitance ?* If there weren't, a single coil would not exhibit a self-resonance frequency.
You mean like this?
If you denoted the H2 field as flowing into or out of the screen then that would fit with the field from displacement current through the capacitor, and would be detected by the solenoid coil.
The single turn shorted coil looks to be slightly tilted from vertical, and that would then see some through flux from the H1 field. Does tilting that coil either side of vertical cause the induced current to go through zero?Smudge
