This is a plot with the TG connected to the input caps (the same as before), but the SA's input is connected to a good* CSR in series with the pancake coils (with the toroidal coil not connected and opened). ... EDIT increased the sweep time from 11ms in the first screenshot to 10s in the 2th
OK, this should illustrate to you that despite the TG injecting a CONSTANT VOLTAGE AMPLITUDE signal into the primary circuit, the current amplitude in the pancake coils is NOT constant. Now, this function of pancake current amplitude vs. input voltage amplitude, must be used to modify the voltage Transmission Loss measurement, which you've already done. Can your SA export it in numeric form (e.g. csv) ...or do I have to count pixels ? All of this is illustrated on the diagram below: Our goal is to obtain the frequency characteristics of the Crosstalk Factor (red) in order to determine what is causing it (electric coupling, magnetic coupling or both...and how much of each). Voltage does not create the magnetic field of the pancake coils - the current does. But we can measure only the voltage Transmission Loss (blue), because our Signal Source (TG or FG) is a voltage source and it is located before the Input Matching Circuit, which has its own frequency characteristic. Note, that I am disregarding the frequency characteristic of the output circuit at the toroidal winding - it is not even present on the diagram.
« Last Edit: 2020-07-05, 20:27:58 by verpies »
