well, things get confusing now, i agree.
To reiterate:
post #773 without white cmc (white trace) 80.4V @ 3.5 to 4.2MHz
with white cmc (purple trace) 10.8V @ 3.5 to 4.2MHz => but output circuit OFF tune now!!
post #776 ooops, corrected the output circuit tuning, now:
with white cmc (purple trace) 91.6V @ 3.5 to
4.5MHz ^^^^^^post #788 white and black cmc trimmed each to be equal value (white 265/265uH, black 231/231uH)
Both cmc's installed, black on output circuit, white on input circuit.
Both circuits tuned to max. at around 4Mhz.
We now have a peak of 30.5V, so much less then the 91.6V with only the white cmc on the output see post #776
Now, when doing a slow sweep (20s) with the both cmc's installed, something got smelly and it turns out to be the input white cmc which gets hot.
I reduced the sweep time to 10s and now its acceptable to 29°C at the resonance peak.
As can be seen in the above picture, the white input cmc is very close to the magnets which probably have a huge influence (saturation) on it, but not sure thats the reason for the heating up.
I will remove the white input cmc now, retune and see what the peak value is then.....
Looking for the Amidon Rf toroids too
