We're focusing on the incorrect topic, forget about dissociation of water molecules, focus on COMBINATION of water molecules! That's is what's important!
To my mind we cannot separate the two sides of the system in that way, dissociation is just as important as recombination. The HELP was designed to add the properties of fluid velocity and pressure to a dynamic electrolysis cell. The question then arose what to do with that fluid flow which is where HELIS came from, becoming the input to the HELT. I thought I could further improve the system which is why the SEC came into existence, effectively removing the fluid velocity from the equation while maintaining the pressure. The LFV designed to pulse and shape the recombination of the Hydrogen and the Oxygen creating a pressure wave that would then be compressed in the RotoMax. The idea behind all this being that dissociation of the water molecule gives you a volatile fuel, the recombination creating a pressure wave that could then be used to violently impact the water molecule inside the rotor, hopefully causing further dissociation of unprocessed water. Dissociation -> Spark -> Recombination -> Dissociation There are different types of dissociation though, heat will cause phase change to steam (energetic water vapor gas) and therefore expansion. Electrolysis causing dissociation to H + O creating the potential for violent recombination. HHO -> Spark -> Pressure Wave -> Steam Expansion Steam gives us a static pressure head, hence the critical valve opening time of a dump valve to maximise power. HHO gives us a dynamic velocity head, creating a pressure wave, and can be triggered by a spark. When we also move into Electrical territory and consider variables such as electrical resistance of the water molecule we do not know how that will change when exposed for a short time to an extremely violent environment. HELIS was designed to test for this by adding the variables velocity, pressure, expansion and contraction. It's a very complex subject and we need data, lot's of it. RIM.
Everyman Standing Order 01: In the Face of Tyranny; Everybody Stands, Nobody Runs. Everyman Standing Order 02: Everyman is Responsible for Energy and Security. Everyman Standing Order 03: Everyman knows Timing is Critical in any Movement.
