2025-04-21, 00:54:43
Pages: 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 ... 21
Author Topic: Ricks best video's  (Read 78351 times)
Moron level of comprehension lesson 2 (ha ha  I am being funny)
https://www.youtube.com/watch?v=XkAMNFKjds4&feature=youtu.be
Minute 7
So Rick finally got me to kick myself when he told me about Don's coil capacitor.
So lets see if anyone is interested.  Which is Don's coil capacitor out of all his well known pics?
Here it is: And it's huge.....
..............As for Don's case, several of them did see inside and saw the small battery. But that again is a matter of testimony. The whole video is just a video and you can't really trust any video. It seems likely that it was not fake. I have some friends who were there so it is different for me than for you. But I can do that so I don't need to that to be proven anymore. But if you watched the video you would see that a 7AH battery cannot power 1000W for even 0.01 of a second. Most people, including all those at that meeting who said something, revealed that they had no experience with batteries under load. This is what I deal with all day long. I will give you the perfect example of what I come across. So we have a UPS and alarm system charger that allows you to keep your batteries for good and not have to replace them. So when we tested the UPS systems. UPS means uninterrupted power supplies, and are used for electronics that you don't want to be turned off when the power can go out. What we found was that their ratings were flat out lies. Even new 7AH batteries cannot power the UPS at all at the ratings/claims they make on the specifications. You cannot have a 7AH battery power a 1000W load at all. The instantaneous voltage drop on the battery would bring it way down past 10.5V so that the inverter would never even run. So as soon as the power would go out on a 1000W load it would be entirely useless. Same at 500W. Realistically you can run a 100W for a bit on a 7AH battery. Maybe just enough to press save on your computer before it dives before 10.5V. ...........................................
Good day All:
Here is a video of a 4 amp/hr battery running over a thousand watts of incandescent lamps.  https://www.youtube.com/watch?v=cni08WjLTcc
This is the Salty Citrus Chinese replication of D.S. table top device.
At the time I was in personal contact with Salty Citrus thru the Sea of Energy F.E. forum in China.
Some where I have posted here on OUR forum some of the information relating to his replication.
He told me that this was not the first attempt at replicating the D.S. device, his group had spent about 5 years to get the device to this point.
It is NOT self-powering as it has the 12v-4amp/hr battery in circuit.  I do agree with A.king and his 7AH battery comment, as a 4 amp/hr. battery will have a difficult time at best starting up a 1000 watt load, let alone running it for 5 or 10 minutes.
1000watt / 12V = 83.3333 amperes;
4 amp/hr. battery == 4 amperes for one hour or 83.3333 amperes for 2.88 minutes in theory.
Of course with a 83.333 ampere draw, the battery will have considerably less than 12 volts across the terminals, so the inverter will do a L.V.D. ( low voltage disconnect).
At the very least, this replication seems to point to a very efficient dc-ac inverter topology.
take care, peace
lost_bro
« Last Edit: 2019-07-06, 04:40:54 by lost_bro »
Good day All:
take care, peace
lost_bro
Good video to learn from.
1 The battery wires are certainly not 1/4 wavelength
2 The location of the battery wires are a mess causing disturbance in the magnetic field
3  No disruptive discharge - they could at least have used a lightning arrestor.
4  No earth ground that I could see.  - so where are the electrons coming from?
5 You would find great difficulty fitting those components into Don's briefcase.
It is what we have all been doing.  Not listening to Don Smith and thinking that the circuit diagram is all there is and ignoring vital sections.  That is why I have learnt a lot from Rick's kit.  Tuning is everything in a Don Smith system.
Don also states to make the 1/4 ratio wires slightly longer so you can tune them easier.
But an interesting video showing what not to do.
« Last Edit: 2019-07-06, 13:12:00 by Aking.21 »
Try and see for yourself and then tell us why you were mistaken. Remember the context of what I wrote: The voltage drop on an inverter will instantaneously drop below 10.5V so the inverter will never be able to run. Depending on the condition of the battery, but even a new battery will drop problem to 1V or lower. And as I wrote, even a 500W load will drop it below 10.5V just as fast. So explain to us why you think otherwise.
I dont want to nitpock as some of his stuff is inspiring...but "you would see that a 7AH battery cannot power 1000W for even 0.01 of a second" is just plain wrong .
10 ms was just a random number less than a second. I really wouldn't want to try that anymore as it would just be a foolish waste of a battery. Of course I have done that sort of thing by accident and caused a DC fire when I joined a string of golf cart batteries with an Anderson connector. You can't put out that fire and it melted a steel tool box down real fast. It ruined those batteries and drained them down very fast.
As I wrote, you can try for yourself and report back your findings. My context was using a UPS system where they lie to you on the back ratings. I deal with this stuff all day long. I knew what to expect, and like I wrote, you really can only use the UPS with a 7AH battery for 100W for a very short time. So it is fairly useless unless you have at least a 12AH battery or bigger. You probably want to do a 35 to 100AH battery for those 500-1000AH systems.
Not sure what 1.2V battery you are talking about. You must be confusing my comments with someone else's.
he stated 10 milliseconds . he did not have to state that yet chose to .but perhaps he mis wrote ?
perhaps we mis read ?.
Any body can misplace a decimal pont ....but even 100 miliseconds is easily doable .
I know! it was a 1.2 volt battery !
its all wasted power anyway ,so irrelevant , as is my question of false fact .
his many students will explain .
A new outlook in tuning is a good thing though.
Do me a favour and get educated on Benitez.  It is there for everyone to read.  It is a free energy patent(s) and it(they) was(were) granted.
The circuit diagram(s) is(are) there for you to look at as are the claims.
I read Benitez patent a few years ago and didn't find any evidence of what is claimed.
Did you build his device? Does it work and is this the reason you promote it?
If you don't answer my previous questions, is it because you haven't read the patent or because you haven't understood it?
I built 2 of the devices and they both worked to a fashion.  However I was looking for 2 plus kilowatts minimum so gave it up.
It is only recently that I have understood the principle of operation so maybe it can be scaled up another way.
The problem was always the damned mechanical interrupters which always broke down on me.
« Last Edit: 2019-07-08, 19:55:13 by Aking.21 »
Here is  a pic of one of them - so you tell me which patent it's from........  If you don't build it you'll NEVER find any evidence.
So I've shown you my evidence - show me yours......
« Last Edit: 2019-07-15, 03:26:22 by partzman »
« Last Edit: 2019-07-19, 15:32:59 by Vasik041 »
A pic is only proof of an attempt, not proof of success. So you built it and you see overunity?
Why are you here still searching?
Answer the question.
partzman
I determined later that nearly 13kw had to be produced for a short period through the earth ground connection in order to melt the 63/37 solder.  At the time this happened, I quickly disconnected the 9v battery powering the device which stopped the light bifurcation echoes from continuing thus removing any further danger.  I will not post a schematic so please don't ask as this device could be quite harmful.
In my opinion what is even more amazing is that the quite large bead of solder which was supposedly molten did not slump or fall vertically. It may have been anti-gravity effects because I have been soldering for around 40 years and have yet to see molten solder on a vertical surface not slump.
Strange but true...
« Last Edit: 2019-07-15, 03:26:44 by partzman »
Group: Mad Scientist
partzman
Strange but true...
Maybe with current flowing through the molten solder, it was manipulated via magnetic fields of the setup?
Mags
I have this as an upcoming kit. I just haven't had the time to finish it. I want to make the booklet better and develop the capacitor teaching more as I did with the resonance kit in the book.
Yeah the interrupter setup is not good for more than short runs. We will be doing a mosfet or transistor setup to replace that in the second Benitez kit. The third setup is the last patent and that is the full Don Smith system. But that is not for the general public.
Anyway, guys, I showed what I called Benitez Switch 7 in video some 2 years ago. It is easy to do with a Model T ford induction coil or an old induction coil used for healing. I have about 20 of these from tiny to large museum size. This is easy to see fast results.
It's easy. You didn't get overunity but it's always frustrating to have to work for nothing, so we want to believe at all costs that we were on the right track...
It's called denial.
Benitez's patent does not produce anything new, it was enough to read the patent to understand it.
We don't know if there will be winners, but we can be sure that those who back down because they are trying to move forward by looking behind them, are the losers.
The future is built on the basis of the past and the present, but the solutions are found by looking to the future.
If there had been overunity in the past, we would have it today.
Hi Rick.
Are you referring to one of these?
Here in the UK they're known as a " Trembler coil " and were fitted to many single cylinder stationary engines. This one of mine still works well.
Cheers Graham.
It's called denial.
Both Grumage and I  discovered the same phenomenon. OU with no input. Don't tell him how Grum, just confirm what I said.......  he's just too annoying.
BTW your trembler is perfect for a Benitez replication - but you need 4 batteries lol
AKing
quote
end quote
thats not how we roll here .....I am not certain what you write about ,but that position reflects
poorly here.
I'd like to share one of my past projects which was quite exciting for a short period of time.  The idea was to drive the trifilar coil with longitudinal RF to excite the negative coupled bucking coils enhanced with P ferrite to produce enough energy to light the LED array.  A ground wire was connected to the shorted brass ring at the solder joint next to the black tape which as one can see is no longer there.
Yes, I've had similar experience with those "light bifurcation echoes" wreaking havoc on solder joints. I was able to tame them with a locus  potentiometer that adjusts the focus of the bias  field to a safe value.
FWIW
FWIW
May I also state that F6FLT is damned insulting in all his posts to me . And that does not sit well either.
From RFQuery
I will be coming up with some kits also. I want to sell a few ounces of copper wire wound on a plastic form with some binding posts for $99 or less, so any info on what "Holy Water" I need to sprinkle on them to be able to market them as free energy coils will be appreciated.
Looking forward to your new kit.
From RFQuery
Stop being rude if you can. I am getting sick of it.
I have shown Chet the unboxing video of Rick's kit.  Let him comment on what he has seen.
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-04-21, 00:54:43
