Good morning Chet.When I got more involved with this line of research and more importantly my internet improved to be able to watch videos in " realtime " I remember watching Kapanadse holding an empty glass at the tailpipe of a vehicle and drinking the contents.Does anyone else remember this?Regarding the patent.... I took a screenshot, presented below.... Wrong forename, perhaps a relation?Cheers Graham.
If we were to consider a hypothetical scenario where the concept of "antigravity" is introduced as a factor in land reclamation or groundwater systems, experts might attribute certain effects or phenomena to this hypothetical force. Here are some speculative effects that could be associated with an antigravity influence: Suspended Water Levels: In the realm of groundwater systems, if an antigravity force were present, experts might observe unusual behavior such as groundwater levels appearing to be suspended or defying gravity within wells, springs, or monitoring systems. This could lead to challenges in predicting water flows and levels. Abnormal Sedimentation Patterns: In land reclamation projects, the hypothetical antigravity effect could lead to abnormal sedimentation patterns in newly reclaimed areas. Sediments might settle in unexpected ways or be transported against the typical gravitational flow, making it difficult to predict the landform changes accurately. Unusual Pore Water Pressures: Antigravity effects could potentially influence pore water pressures in the subsurface, leading to anomalous hydraulic behaviors. This could impact the stability of reclaimed land, causing unexpected seepage or drainage issues that are challenging for experts to explain based on traditional hydrogeological principles. Disrupted Ground Settling: In land reclamation projects where antigravity is considered a factor, experts might observe disrupted ground settling processes. The absence of typical gravitational forces could lead to uneven and unpredictable settlement patterns, affecting the long-term stability of the reclaimed land.
Among the effects listed in the hypothetical scenario without considering antigravity, the following could be considered anomalous based on conventional scientific understanding: Suspended Water Levels: This effect could be considered anomalous in groundwater systems because water levels are typically governed by gravitational forces. If water levels were observed to be suspended or defying gravity within wells or springs, it would be a departure from the expected behavior and could be seen as anomalous. Unusual Pore Water Pressures: Anomalous pore water pressures in the subsurface can indicate abnormal hydraulic behaviors that deviate from typical patterns. Variations in pore water pressure can affect the stability of structures and landforms, making it an anomalous phenomenon that warrants further investigation. Disrupted Ground Settling: Irregular or disrupted ground settling patterns in land reclamation projects would be considered anomalous, as settling processes are typically influenced by gravity and follow predictable patterns. Any unexpected settlement behavior could signify underlying issues or complex factors affecting the stability of the reclaimed land.These anomalous effects would likely prompt experts in hydrogeology, geotechnical engineering, and related fields to investigate further to understand the underlying causes and assess potential risks to infrastructure and environmental systems. By identifying and addressing these anomalous phenomena, professionals can make informed decisions to mitigate potential hazards and ensure the safety and sustainability of land reclamation and groundwater management projects.
The effect that could potentially lead to the registration of hydrogen evolution in the context of groundwater systems is: Unusual Pore Water Pressures: Anomalous pore water pressures in the subsurface can sometimes lead to the release of gases, including hydrogen, from the groundwater. Elevated pore water pressures can influence microbial activity and processes in the subsurface, leading to the generation of gases such as hydrogen as byproducts. If experts observe hydrogen evolution in groundwater systems, it could be linked to anomalous pore water pressures and associated geochemical reactions occurring in the subsurface. Monitoring and registering hydrogen evolution can provide valuable insights into underlying hydrogeological processes and potential environmental impacts.Understanding and monitoring these phenomena can aid in assessing groundwater quality, identifying sources of contamination, and managing groundwater resources effectively. By recognizing hydrogen evolution and its relationship to anomalous pore water pressures, experts can investigate the underlying mechanisms and implications for groundwater quality and environmental health.
Water can not be compressed ever.
But if you go up Mount Everest and boil water, at what temperature will it be boiling at?
