These coils are pulsed with HV DC pulse of short duration (1500v minimum), while DC of 24v, through a 50 ohm rheostat to adjust current, is applied to the outer coil.
When pulsed, some sort of field or particle effect is projected out in all directions.
I am trying to figure out what this effect actually is.
A few ideas, partly based on old Borderlands clips: - Attraction/repulsion to metal foil - Attraction/repulsion to dielectrics (scotch tape) - Test for anomalous capacitor charging in-field(ground one lead?) - Could try using iron filings and applying a single pulse to see if a pattern emerges? - Test for film exposure to field (X-rays or something with similar effect?) - Test with foil or plate panel to see if the field can be focused/steered/reflected.
