Hi guys,
Have a look at my test. I don't get the same results as Itsu
https://youtu.be/F3C5opU3koY
Luc
Hi Luc,
thanks for the tests and results.
But the circuit used and tests carried out are not the same as i (we) are doing in the real circuit or the simulations
so results can not be readily compared.
Please allow me some comments:
First the diagram shows the red plus (+) sign at C2 in the wrong position.
Secondly, the yellow input probe was never at that position in our tests, it was always across the source (battery).
Then, your Caps are different (much higher in value), same with the load (we use leds).
Not sure about the switching device, we used a transistor at first, now a MOSFET.
Concerning the measurements, please use "mean" for the currents (so not rms or cyc rms) and many cycles so we can
compare with our results, see my screenshot above.
You can use cyc mean, but that will take only 1 cycle no matter how much cycles you put on the screen and we have seen
that 1 cycle could mislead you here.
Try to use the same vertical / div. setting when comparing currents through csr1 and csr2, i notice it can differ
somewhat when using different settings.
Finally, we use a floating FG which is directly connected across the base / emitter (transistor) or gate / source
(MOSFET) to prevent from any FG currents to being added to csr2.
It did add "SOME" (so not ALL) extra current through csr2.
