Way to go guys.
I had the same problem using the big 470uF cap, so i used smaller ones before (6uF). I think its caused by the slow charging rate (low output current). If you wait enough (60 second or so) it will slowly have build up.
Not sure you guys already know, but:
doing a "cntr / LEFT mouse click" on the f.i. (red) Ic(Q1) readout in the trace screen, it will display the average and rms value of that trace.
doing a RIGHT mouse click only shows a screen where you can select Attached cursor (none, 1 or 2) to set in the trace screen to measure like frequency between 2 peaks etc.
pushing the left alt key when showing the current symbol over a component (like E1) shows a power meter and creates power trace.
Nice tool.
Itsu , many thanks by the tips about hotkeys  really easier that way! I start think the problem it's related to the fact that I'm running LTspice in Mac Os, because i not able to overcome some small issues . Now i able to run but without same result you and Gyula have , i will post later some of my shots , but maybe i will try to virtualize a machine with windows and try in windows plataform . Another question , is how is it possible to simulate the push bottom function, like in the real circuit to start the oscillation? Is that possible ? Like i told yesterday , I don't usually use Ltspice to simulate circuits, and all free tips are welcome. PS -Im waiting to receive a call from a friend of mine , to try borrow a LCR Meter . Maybe i could have today the right values
« Last Edit: 2020-04-27, 14:47:34 by nelsonrochaa »
Best Rewards Nelson Rocha
" The goal is not to be successful, the goal is to be valuable. Once you’re valuable, instead of chasing success, it will attract itself to you. "
