Photons? I suppose that's possible...
Use for DSRD? Laser Pulse generators. Apparently if you pulse high voltage you can produce photons?
(Drift/[there's some other D word I've seen] Step Recovery Diode). Some would say they are ultra fast recovery diodes for high voltage; but in their relaxaction phase they generate a higher voltage pulse. And this pulse is certainly low current. So I got as far as page 4 of this document that's been resurected from history to compare the design to the dally generator. Was coming over to see if I could talk with Itsu about his experiments.... Because he's testing the effects devoid of the whole process.
I've been playing on-and-off with that
Dally generator/Kapagen-like thing. The peices, in isoation, behave differently than when built in as a system. It's hard to isolate the parts.... At one assembly point, the resonant flywheel coil was resulting in a nice square wave back to the original pulse generator...
But, The uhmm bias... Eventually some of it can float, but... Like the resonant flywheel coil has a leak point with a pointed connected to the capacitor, eventually, it will overall have be a positive circuit, but it wouldn't really bias the whole thing in a direction.
It's interesting that a ground between two coils in series acts as a diode and only permits a single direction of current through the coil...
But uhmm...
I didn't make it through this document, just got to page for that descirbes the operating characteristics that I observe in my replication.
I made this for a
pulse shaper]https://www.circuitlab.com/circuit/2spe6k/mosfet-mosfet-driver/]pulse shaper... so I can take a wider (250+ns) pulse and take the leading edge (30-40ns minimum). Have to make sure the caps are sufficiently small to keep the current short(to drive the mosfet gates), yet large enough to generate a solid high voltage ON condition.
And was trying to find a simulator that works to see the results of
www.circuitlab.com/circuit/qb8znp/oscillators-joule-thief-signal-generatorI do have a simulation in LT spice that works pretty good... but I don't think it includes aether effects (or photon generation)
At least to see what this set of coils really does interacting with itself... But it suggests that decreasing the capacitance on the coil-capacitor closed loop (resonant flywheel) circuit increases the voltage in the fly wheel; because it is driven by the original input, and then left to relax. But overall there is a large combination of factors that control the frequency, so tuning this sub-circuit to some specific frequency becomes self-defeating, because it should be close-enough, then tuned for highest voltage instead.
(continued) Hmm, the designs and are somewhat orthagonal to each other, since dally is a tube design (which I guess would be a segment of the toroid)
Nope; this is entirely the wrong thread, other than the theory... really I think dally's thing works in the same idea as the theory here... (but I didn't find that thread until I posted here, and referenced it)
