I think at 800KHz or higher you just have some resonance effect with parasitic capacitance. Have you tried attaching some load resistors (to Vout on your schematic) ?
No resonance. Same level from 800 KHz up to 3 MHz or 4 Mhz (resonances are above). With a load resistance of 1 Kohm, Vout is divided by about three. I have just improved the configuration by putting an isolation transformer (which is also a toroid with 2 coils) between the FG and the toroid to be tested. Then I can connect the oscilloscope ground on either side of the bi-coils. Same measure! I have about Vin/10, which I measure from one side or the other. The configuration being now symmetrical, this means that it is the choice of the ground point that determines the coil on which only Vin/10 will be measured. We face a measurement problem.
« Last Edit: 2019-01-05, 16:15:48 by F6FLT »
