2025-07-26, 04:37:33
Author Topic: Non-linear capacitors  (Read 13838 times)
"Nickolay E. Zaev worked on creation of the prototypes of converter energy, which do not require
any fuel. The direct conversion of environmental heat to electric power is possible in the processes
of charge-discharge in non-linear capacitor or by means of magnetization-demagnetization of
ferrite. Such converters of energy create cold and electric power without any fuel."
Some efforts were made to reproduce device based on non-linear inductance. It seems to be very difficult
obtain any significant (measurable) amount of energy using standard and widely available core materials.
It was not possible to experiment with devices based on non-linear capacitor because there is no such capacitors.
However, recently I became aware of chip (SMD) capacitors with X5R and X7R dielectrics. These dielectrics contains BaTiO and have interesting properties I would like to demonstrate.
But for beginning - N.E. Zaev "Research on the Capacitance Converter of Environmental Heat to Electric Power"
http://jnaudin.free.fr/doc/Capacitance%20converter.pdf
« Last Edit: 2018-12-21, 17:25:08 by Vasik041 »
More Zaev's papers
In first experiment I charge capacitors from constant current source and discharge through small resistor.
On pic. 1 (attached) shown capacitors I tested
and on pic. 2 scope traces (yellow - control signal, blue - voltage on capacitor)
There are only 3 set of traces, bank of non-electrolytic capacitor behave same way as electrolytic i.e. is is linear
In second experiment I replaced discharge resistor with constant current sink.
And last experiment I tried discharging capacitor with very short pulses (5us) through small resistor (4.7Ohm)
Attaching traces for linear and nonlinear capacitor and graph how capacitance (C) depends from voltage (U) cal from this traces.
One piece of lost knowledge from 50s, time of electronic tubes.
In tube amplifiers, capacitors between amplifier stages were often under significant bias
voltage (because one side connected to anode and other side to control grid)
Bad capacitors often caused distortion and even oscillations.
Possible practical application of non-linear capacitors - Weber circuit, supposingly self running.
Here is the page in German with one of Webers circuits:
https://www.psiram.com/de/index.php/Gustav_Hans_Weber
If anyone has more information about this, please share.
Dear Vlasik
Thank you for all the info generously offered on non-linear capacitors as a possible source of excess energy.
I recall the work of Zaev first seen on JLN site many years ago, but I never pursued work in this area.
Have you considered double layer caps or supercaps for these experiments as they have extreme non-linear V vs Cap curves, but the slope may be in the wrong direction.
Thank you ION,
I tried using super capacitors for energy storage, e.g. run joule theft, bit not for these experiments.
Supercaps have very big capacity and charge/discharge cycle will be long or very high currents needed.
-V.
Thank you ION,
-V.
Yes large capacity, lower switching frequency, high currents involved, however, more energy delivered per cycle.
Also note that the currents used in the charge / discharge cycles need not be lost energy, as these heating effects are still recoverable as part of overall input energy.
e.g if the entire apparatus were run in a styrofoam box and temperature rise noted, we could compare against a equivalent resistor fed from a power source to determine comparative heating / cooling effects over a long period of time.
If there are exothermic or endothermic factors, these can be separated out with a careful test setup.
I have noted extreme non-linear behavior of double layer caps, but agree the time constant is long. I did charge / discharge using a current source and paper strip chart recorder, then held a ruler against the produced graph. Of course this could also be done with a data acquisition device and PC.
I need to refresh on Zaev's work.
Question: In a non-linear capacitor based energy gain system, do the opposing plates of a capacitor demonstrate a temperature difference? Been a long time since I read Zaev, but seem to recall this being mentioned.
I can't remember such detail. As far as I understand energy comes from dielectric's heat and I would guess that both plates cool simultaneously. This is similar to magneto caloric effect (https://en.wikipedia.org/wiki/Magnetic_refrigeration).
from Zaev's paper:
"Energy is taken from free (heat) energy of ferroelectric. B.B. Golizin (https://en.wikipedia.org/wiki/Boris_Borisovich_Golitsyn)
 showed the possibility of such mutual conversion in dielectrics in 1893 [5]. It is a pity, that there are no mentioning of this basic
 article by B.B. Golizin in any works on thermodynamics of dielectrics."
-V.
Got to thinking about Hans Weber's self oscillating circuit and thought I would play with it on paper before going to the bench. In the process I think I have boiled down a few simplified versions that may eliminate the need for a transformer, and in the end can use an inductor (or tapped inductor if the original FW rectified version is preferred).
In one version, I have preferred to make three items tunable such that a sweet spot can be found.
Note that quite possibly a lower value of storage capacitor and a half wave rectifier may provide more "pumping action", but this is TBD.
Also a non-linear load may facilitate operation.
The initial startup can include a signal generator and loose coupler to induce operation while tuning for the sweet spot.
Unless the original circuit relies upon leakage inductance in the 1:1 transformer, I see no reason why the simplified versions using an inductor would not be worthy as primary to secondary isolation is not required.
« Last Edit: 2018-12-24, 20:02:57 by ion »
As far as I understand simplest setup is just L, non-linear C and voltage source for offset.
I am trying figure out what is condition for non-damped osculations, but so far did not get it.
-V.
-V.
I think the bias voltage on the capacitor is a requisite for oscillation, which an LC alone does not provide. The proper point on the capacitor's non-linear curve must be found, I presume.
Reversing charge on the capacitor probably doesn't get you to the sweet spot on the non-linear curve.
As someone said: "things must be made as simple as possible, but no simpler". (don't remember the exact quote by Einstein?)
edit: Attached is a proposed test setup using a signal generator with LF offset output to induce a variable bias on C2.
       Look for small HF burst as variable V traverses sweet spot.
« Last Edit: 2018-12-28, 14:10:57 by ion »
Hi all,
I was "Exnihiloest" in the past and I am now back with my ham radio callsign. I left for reasons that are no longer valid today, so I am very happy to be back among you, especially since some of you asked me to on ou.com, and I greet the former contributors I have known here, as well as the new ones.
This thread caught my attention because I'm experimenting on dielectrics. For me parametric systems like non-linear capacitors cannot a priori give overunity because it takes energy to change a parameter, like reducing a capacitance to increase its energy by virtue of W=Q/C. The energy required to reduce C is exactly the electrical energy that will be recovered in W, this is easily verified for a parallel plate capacitor.
But what if the capacitor is "open" and the energy for parametric change can be drawn from the environment? Then non-linear capacitors could be the gateway to the hidden source, which could be ambient heat (Maxwell's demon), LENR, ZPE or other unknown sources...
I am now investigating the first case, according to Zaev's idea, and so I am looking for a dielectric whose permittivity decreases when the temperature increases. Did you find one? Because in general, what we find is the opposite. If anyone has an idea, I'm a taker.
On my side I started to test ferrites as dielectrics. It is known that they have a high permeability but less known that they also have a high permittivity, depending on frequency (and perhaps temperature?). NiZn ferrites are the first ones I test. There are other types such as MnZn with higher permittivity but with too many losses because they are not insulating enough.
I think this is a little explored field, including interactions when the two magnetic and electric fields superpose in ferrites and could have cross parametric effects. Just an idea.
François
Francois
A large welcome back, you were deeply missed when you left as I (and others, I'm sure!) greatly valued your input and always learned something. Looks like you have a good grasp of what is needed for parametric operation of capacitors.
Hopefully we can try a few ideas.
Kind Regards
Hi François,
Welcome back!
These capacitors I've been testing decrease capacitance with temperature.
I found this video https://www.youtube.com/watch?v=j0MLo_BYLHQ but haven't tried it myself.
Capacitance decrease with temperature rise and this cause voltage rise also.
My goal build device which does not require heat source (except ambient environment heat).
It would be nice to learn more about your experiments.
-V.
PS there is related thread about ferrites  here http://www.overunityresearch.com/index.php?topic=3453.0
Perhaps you find it interesting.
Hi all,
[snip]
François
Hi Francois,
Welcome.  Perhaps you may find the attached papers interesting regarding an anomaly I found in a few MnZn ferrite cores some time back.
Thank you everyone for your welcome
@Vasik
Do you know what this "nanocrystal" is, which is referred to at https://www.youtube.com/watch?v=j0MLo_BYLHQ_BYLHQ that you have given?
That is what we need. Someone says in the comments that it would be a tantalum capacitor.
It would also be interesting to know if the effect is reciprocal, i.e. if reducing the voltage reduces the temperature (if there is an effect, it must be small, and I am not equipped for this kind of measurement).
@Partzman
We saw on ou.com how difficult it is to measure high frequencies. I just screwed up right now while playing with my NiZn toroids  :(!
When the COP is large, for example >3, it should be possible to replace the FG with a low-consumption 1 transistor oscillator, which could be powered by the rectified output of the setup. It's easy to build. I think that's the only way to be sure of the COP.
I guess it is SMD capacitor. I tested capacitors with X5R and X7R dielectrics. They are really non-linear (see beginning of this thread).
As far as I understand, we can have OU heater or cooler, similar to magnetic refrigerators.
With regular ferrites temperature difference is very small. I haven't tried yet with capacitors.
If you charge(discharge) capacitor fast enough, you create rapid entropy change in dielectric and it will cause interaction with ambient environment (temperature difference).
-V.
I tested several capacitors and found only one whose capacity decreases with temperature, it is a component from the 60s, see the scan (it's the first time I scan a component instead of making a photo, it works well  :) ).
The effect is only a few % on the resonance frequency from 20 to 70°. We would need much more non-linear components. I think that temperature stability is one of the criteria for choosing dielectrics in industry, so I don't think we can find very effective ones, i.e. with a large and tight variation as a function of T. We'll have to find the right dielectric.
Hi Francois,
Hi partzman ,
Very interesting anomaly that I confirm.
I tried with 3 toroidal coils from the electronics industry (I didn't wind them myself). The ferrite is likely NiZn for all but not sure.
One has its two windings wound like a bifilar coil. The other two have two diametrically opposed windings.
At the middle point, when the connections are made in such a way that the windings oppose their magnetic fields, I have less than a tenth of the input voltage, whereas we expect half. Same result for all three.
In fact as both windings are opposing, with ideal coils 100% coupled we would have a short cut and the FG coudn't generate the signal.
So we have to deal with non ideal coils. I made a LTspice simulation. While the coefficient of mutual induction is less than 0.9 (which is a good coupling), a generator with a 50 ohm impedance provides enough current to maintain a voltage near to that one in open circuit. Nevertheless the simulation shows half the voltage at the coils mid point, regardless of the coupling coefficient and of the loss in the internal FG resistance.
Very strange, I don't have an explanation yet.
Hi partzman ,
Hi F6FLT,
Yes it is puzzling!  I had purchased a number of these cores on Ebay and I used this particular one on a number of bench tests over time so I may have "conditioned" it somehow along the way.  I initially suspected magnetostriction so I placed felt on the inner and outer edges of a virgin core to float the windings off the core and it did exhibit some voltage increase at the tap.  I had planed to 3d print special covers that would allow as little support as possible for the core and windings but haven't done this to date.
A similar condition can be forced with a capacitor connected to the tap but it is not asymmetrical like the anomalous core.  This led me to believe that perhaps it might be related to the permittivity of the material.  I've attached a paper relative to the dielectric measurement of ferrite materials that I had used for study.
@partzman
I just tried with a very large 9x14 cm rectangular ferrite core with a 3.3x3.3 cm square section, which was used in a KW power supply.
I have no anomalies.
The difference compared to my other tests is that here the coils are strongly coupled, distributed on both long sides of the rectangar core, and wide to the point of touching in the middle, so that it seems impossible to me that the opposite flux loop between the two coils.
I also tried with another toroidal ferrite, smaller than the other three already tested. I have the anomaly, with always Vout about equal to Vin/10.
Could it be that the anomaly only occurs when the 2 flux can loop back between the two coils?
Have you some ferrite toroidal core with no anomaly, and if so of which geometry?
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-07-26, 04:37:33
