2025-04-20, 19:44:27
Author Topic: Cool Joule's wheel  (Read 1242 times)
The builder formerly known as Patrick (iirc) and now Cool Joule seems to have finally cracked something with the old familiar Bediini SSG.
He uses a reed switch with a separate 1.5V battery to swith a transistor. Pulses are dumped back into a capacitor, which at approx 13V dumps to the drive battery using a 2 pin backwards connected transistor. That breakdown thus forms the dumping method.
Apparently he's been running it for 2 days and it has increased the charge on the run battery by a couple of thousandths of a volt, plus the 1.5V batt will run for a year.
A couple of air coils around the outside, or, something light of a generator hanging off the motor shaft might make a spectacular machine out of something we have all likely built before now.
https://www.youtube.com/watch?v=RyaEgvN2IUA
It uses a 9 stranded coil, 8 + trigger, which 'balances' the machine with different input voltages. For example using 9V, he only uses 5 wires. Had never heard of that before.
« Last Edit: 2018-04-22, 17:13:41 by Slider2732 »
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-04-20, 19:44:27
