Regarding Keshe, interesting that he uses the nano-coatings....should also work on an insulator base if he is correct. Does anyone have any of Keshe's stuff working to demonstrate his claims?
Keshe falls into an odd category where there are few groups exist with the technical prowess to replicate if they wanted to. Intense vacuums, careful machining, electrochemical deposition, and precision gas-distribution is not easy for a garage tinkerer to replicate. The teams that do get positive results are probably under budget to someone and thus bound to NDA's (assuming the technology actually works) . --------------------------------------------------- Regarding possible metal compositions used, we have to consider SM's words and his position in the music industry. For wires other than copper, I suggest we consider the following: * Iron/magnetic steel (mentioned throughout his emails, especially the NMR post). Common as ' Bailing wire' and SM referenced to iron nails being ' bent and shaped like cork screws' after TV explosion. * Aluminum wire (bailing wire). * Tungsten wire ( a literal interpretation of sm's vacuum tube descriptor). * Brass wire (commonly sold as music wire) * Stainless/high-carbon steel (non-magnetic, used for guitar strings and thicker wire is used as bailing wire). * Brass wire twisted on steel wire (also music wire, guitar strings) * Litz wire (' many short pieces of wire' quote) * Silver coated wire (not mentioned by SM but used in high-end wiring, and often referenced in the OU community) * Nickel wire (also not mentioned, but the only other common ferromagnetic metal available. Used in MuMetal and high permeable transformer cores. Sometimes used as resistance wire) * Solder wire (Bismuth/Lead/Tin/Indium/Zinc alloys).
« Last Edit: 2018-06-05, 04:12:38 by Reiyuki »
