Not to detract from the current effort. it's opposed which releases the energy in another form. This can be used as successful units (I guess) employ this release. With identical resonances in opposition I'd also expect to see high currents at the nodes. This does sound familiar.
Don and Vlad state that the energy(the other magnetic field) comes out at a perpendicular angle, 90 degrees. They also tout activity of a field within a field. This fits with what we are trying to see. If you google 'Don Smith's Multicoil', click on the images. There are links that show the Kunel type builds but with opposing magnets applied. This fits with the Apartheid capacitor configuration. Look at the description under each link. Heavy into the physics of the charge storage which makes perfect sense. Now comes the effort to tie this current effort to the partheid process. I believe they are closely related. Step one is to charge up then step two withdraw charge in a different way. Because they all say you can not withdraw energy in the normal fashion. SM stated you connect to ground you lose the energy. Don Smith also stated: 'I will not disclose how it works. I have shown in detail all the builds. Let them figure it out.' Then there are all the standard trained saying how it doesn't work because of a misrepresentation of Ohm's law. Interesting and gratifying at the same time. With the Apartheid cap we have access to forces of differing angles instead of these being contained in an inaccessible place like the capacitor can. And like Wattsup stated that we can then use two of the iron wire build next to each other. This would place nodes at certain places of the air based capacitance. This is not unlike a Tesla coil with the air based capacitor of the secondary potential from a ground reference. And the coupe de grace is SM mentioned kicks and the Apartheid cap needs a kicker coil to start the process. I just happen to have an Apartheid cap lying around. This one I had put the Tesla coil primary pancake on and kicker coils on each side.
« Last Edit: 2017-08-17, 20:43:42 by giantkiller »
