Doing anything is not proof of invention. "An invention is a unique or novel device, method, composition or process. The invention process is a process within an overall engineering and product development process."
Under Legalese, an Inventor is someone who makes or designs something useful which hasn't been patented or placed into the Public Domain. Anyone who comes up with a working variation of the MEG. As an example. Or a Fusor with an output socket. Dr. Paul Brown, a brilliant Nuclear Phisicist, Scientist and Inventor, said he found a new way to get electrons into a wire. What he apparently did was tap the duality of an electron's wave/particle manifestation, relative to the seething mass of electrons in and around his chunck of Cessium. He built a receiving coil antenna in the form of a ring of transformers to allow the wave function to transfer into the primary windings, with a tuning cap providing a desired output frequency. The secondary windings are how output is taken from the passive resonance surrounding the isotope. I've been around for a while, building my understanding. I remember a forum discussion about the 'technical' beginning of the new Mellinnium. And I'm also technically an Inventor, with a patent listed under my name (4,260,933 - Optical Generator). (I'm selling those ResMods). I'm going to try Dr. Brown's transformers around the outside of my Fusion Spark. It's known in the Prior Art that an arc will support six lengthwise nodes around it's perimeter. So that's how many transformers I'll try. About the MEG, I got a couple of square florescent tubes, about the size of a quarter and a good 1/8" thick. Plasma normally blocks magnetism, but I doubt there would be much of that with such a wide pole gap. So I'll see if I can polarize the plasma, to provide permittivity through the gap. Using an on switch rather than trying to make an off switch. ***** edit: Quoting Aaron Murakami : "Don't you start thinking about his patent; he's just trying to relive the glory days when he Had a patent. And it's just one more tube with a spark in it."
« Last Edit: 2022-04-22, 19:33:15 by Jerry Volland »
