The idea came to me that a ordinary electronic vacuum tube (valve) as used in old equipment, radios, TV's etc. can be used as a power monitor by putting the power input into the filament and reading the emission directly from cathode to plate in millivolts or microamps with a DMM. No plate supply required! This gives us a nice thermal RMS converter without having to mess with thermocouples, thermistors, infra red diodes etc. The filaments on some have very low inductance due to folded construction. From about half a Watt to 3 Watts it is usable, and as always you should prepare a chart of your own particular tube as your "standard". In this particular study I took a type 6AL5 dual diode, and put increments of voltage into the filament, up to 8 volts which is a bit higher than rating but that's okay, I've got boxes of them. Next I will try some interesting tubes as used in portable battery radios of the 40's and 50's, pre transistor. These were the "1, 2, 3" series tubes. These tubes have very low filament current ratings. Maybe I should have called this "Fun with vacuum tubes" because it is fun to find new uses for old. Before the naysayers step in and point out all the potential problems, I'm just having fun, I know there are problems around every corner, and I can if I wished point many of them out e.g non-linear filament resistance, not ruler straight, etc but lets have some fun on this journey.  Perhaps Graham is old enough to appreciate this?  Maybe I should start making youtube videos of this stuff and begin watching those pennies from heaven rolling in.  A little dishonest title like " Free Energy From the Vacuum (tube) Giant Overunity Heat your house Free" ............well, not my style. https://www.youtube.com/watch?v=EXIK9YkwIqA
« Last Edit: 2017-05-19, 15:06:13 by ION »
