2025-04-01, 01:43:34
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 [13]
Author Topic: Using the Earth's vector magnetic potential  (Read 111119 times)
Everyman decries immorality
Bump
Grum its time to talk again about your Needs for the tachometer or Whatsit? for your Smudge experiment.
Just Hung up with Slyder
He's gonna double check the "needs" here .
and then we move forward .
thanks
Anyone able to provide a synopsis, bring us all up to date on what you are building, and why ?
Hi Rob.
You remember this?
https://youtu.be/koJ0qHNWlBM
And here is the suggested test protocol.
http://www.overunityresearch.com/index.php?topic=3395.msg60483#msg60483
There's a few loose ends to tie up, consistent starting actuator, accelerometer and a suitable platform to conduct the experiment.
Cheers Graham.
Hi Rob.
You remember this?
Yes mate, had a lot going on lately and thanks for the refresher, I remember.
It is an interesting experiment, certainly original, and has a group participation rate that is an indicator in and of itself.
Forward message from Slyder RE Grum's build of Cyril's new experiment.
Slyder
Demonstration of the software running.
https://www.youtube.com/watch?v=1JH9m3Low9c
(3min 56sec)
The camera was on low battery, sorry for the rushed recording.
Output of the 555 timer section is from a pin on the Arduino, which will be a post to clip to on the built unit.
 When made, it will 'ship' with running code, plug in and play. Updates to the code will be as and when time permits to make it a multi-use device in the future (different sensors, range finding, temperature/humidity, multimeter type uses). Hence the talk of downloading software...only needed for future updates.
Cheers
Mark
Mark is just about ready to ship .
looking quite amazing ...a beautiful tool for this experiment .
https://www.youtube.com/watch?v=oE2qCFhqnfU
what an amazing group of fellows here !!
  Awesome work, Mark - as always!
Great work Mark
Hello All.
Just a quick note to thank all concerned, the " Gizmo " has arrived safely in North Wales.
Cheers Graham.
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-04-01, 01:43:34
