2025-03-31, 17:30:01
Pages: 1 [2] 3 4 5 6
Author Topic: Space: The final frontier  (Read 51392 times)
GK
Quote:
Superliminal Heterodyning Integration Transmitter.
Next Time you go on vacation.
Can I carry your luggage around?
Sounds like your having to much fun??
PS
Szaxx
Is that a new coil ? or a pic of something from 2001[A Space Odessy]
PPS
Looks very familiar?
@Chet,
You can carry my luggage only if it is going the same direction I am going.  :D
Hi All,
@chet Nearly...its a design based on wilbert smiths cad coil or a variant i have been toying with... the idea is to get all even number loops on the top and all odd number loops on the base with the first loop finishing directly below the start point and then winding so the alternate ends finish up 1 notch BEFORE the last odd/even run.
sounds a bit confusing but nature likes things this way and then (theoretically) looking at the magnetic fields produced working in vectors of course and the effect I was hoping to create effects the outer field in a way to act as a magnetic bearing.
B field hopefully will orientate itself without twisting giving gain in the secondary...thats the general idea.
trying a pic.
the coil is 160mm OD and 95mm high cutting in 5mm slots each end. The notches are 1/4 inch apart making 80 in total. the wires go in at notch 31 loop around the back of the stud and out at 32. The wire goes in at the empty stud before the prevoius loop and out at the same exit the previous loops wire goes in.  They are built similar to the agent gates  way.
cheers ste
« Last Edit: 2010-02-04, 15:07:53 by szaxx »
Hi,
Having a little trouble with this machine......
originally the scope shot first is the output 1 loop pickup on all shots.
Using a BU508 transistor it gave no output worth using.
the second shot. top tace is the output as clean as I could get it lit bulb. The lower trace is at the gate of the fet IRF840. When you increase the input fron zero the gate signal seems to go to near flatline ..further than that the spikes go mental over 400 volts out and theres lots of em too. Its powered with 12V batt and limited on current .3Amp or so shown. the bulb is low voltage but nearly burns out when input increadsed with little more drain from supply.
Interesting effects when changing freq using sine input.. the brilliance increases when shifting freq and the unit sings around 9KHZ but nothing is secure on the coil.output coil too tight to fit so will get it rewound as soon as poss.
Cheers for now Steve
Ken posted this in a chat session so I thought I would expose some more info.
What 2 driven wires do...
« Last Edit: 2010-02-04, 21:14:01 by giantkiller »
[youtube]http://www.youtube.com/watch?v=isfLm7r6fb8[/youtube]
I switch direction connections and it makes no difference.
The TPUs are a resonance generator much like the rotoverter. The generator sits parallel to the engine. Each field complements the other by reflecting back back and forth. This is why the rotovertor model on the single shaft in series does not work. The single shaft does not convey the resonant field to the load nor vice versa.
« Last Edit: 2010-02-15, 02:41:18 by giantkiller »
GK
This [if the link connects] looks like a similar configuration to the above
Courtesy of "wings"
http://translate.google.com/translate?hl=en&sl=bg&tl=en&u=http%3A%2F%2Fmazeto.net%2Findex.php%3Ftopic%3D897.0
yes. ECD type
GK
Courtesy of "wings"
The difference between the BTC(Bruce_tpu coil) and the GK4 is the BTC is sequenced in a circumferal field while the GK4 jacks a toroidal field.
The BTC heterodyning causes a precession of Bloch wall perturbations much like the Rodin coil. This is further enhanced by the interleaving of the control windings which are steel. The GK4 uses iron with radially dispersed control windings. Both create a bias field or flux field for additive control.
The BTC has a circumferal field created by the vertical steel control windings. The GK4 has a toroidal field created by the horizontal iron loops.
This is the main difference in geometry.
[youtube]http://www.youtube.com/watch?v=Hq1lhuBFmDI[/youtube]
« Last Edit: 2010-02-20, 06:20:10 by giantkiller »
[youtube]http://www.youtube.com/watch?v=0NkyT3i3F5M[/youtube]
1 freq square wave. Have the GK4 Otto mobius winding diag that I will apply next..
I ran a square freq into the steel and another square freq into the copper with 120v across the coil.
The scope shows 12.7mghz. The pc speaker has a .5 second chirp window with what sounds like 1khz.
If I change one of the freq the GFI plug in the other room chatters off and on. But the PC never falters. ???
I am back on track with using 2 or 3 freqs and square waves doing the bifilar testing.
BruceTPU needs 3 freqs because he has 3 different control wire lengths and they are steel.
The GK4 needed 3 freqs because the collectors were iron and all control windings are the same length.
The sm17 showed antenna wire outer wrap of 2 wires, 2 freqs. Or a piece of iron wire in series with one of the runs. Only 1 freq needed to produce the comp wave on the outer wrap. This would impinge on the 3 horizontal rings in the antenna wrap.
If I can bang a GFI at a distance then hitting a copper loop in the vicinity should be no problem.
Another dangerous coil on the bench. This is why I stopped. The wife gets really pissed!
Think I'll play my guitar and let this settle on my mind a while.
@GK
If you add a center toroid, then the PC will turn on and off programs. lol
[youtube]http://www.youtube.com/v/thxPgGatkd4[/youtube]
http://www.overunity.com/index.php?topic=8227.msg230142#msg230142
The 2 frequencies are 21hz and 200hz.
http://www.youtube.com/watch?v=Opb0LvX7jZY&feature=player_embedded
Two things:
The ring configuration is in the vein of the ECD and the scope shot shows major promise. The ringing shows up symmetrically in the on time. But the off time has a higher peak to peak and faster oscillations. This is most important! The self oscillation start is in the off time. His scope shots show the same pattern I started with. The next test is to reduce the on time or change the on time to 25%. His signals are 75%/25%. You want the off time oscillations to overlap the back end of the on time ringing. In other words 'The two sets of waves will overlap'. ;) Then you see the consecutive spikes building. We push the swing at the correct time...
The constant DC at the back end of the on time stabilizes the polarity of the electron torque. All is quiet. This stops the oscillatory function. Then the off transistion has to start up again only to loose any reverberation that might happen. The reverb or echo is necessary to start an acoustic or wave tidal imposition. This whole process uses the established wave content or standing wave as a bias or stored energy. That is the constant resource that resonance supplies.
Here is what I have seen: The coil produces intense noise in the off time. If the duty cycle is lowered the next check is to see where the off time oscillatory function stops along the off time window. If it stops short of the impending on time occurance then 2 things have to occur. Change the input frequency or the coil winding/configuration. Sm stated he 'snipped wires'. This can happen in alot of ways and do alot of things.
Now the unfortunate news:
This is the feedback process that is like a teseract in a house of mirrors. You change one parameter then go to another part of the configuration and adjust something else. It could be electrical or mechanical. That is the nature of the beast. I got to this point and the next step is to work the power output stage. In other words: Once you have established the echo you then need a target. Whoa!
Previous efforts have attempted to drive a coil to get power. This is basic transformer action and will not work. Doesn't matter if you use square, sine, or spark gaps. Just because you step on the gas doesn't mean you'll make it around the corner faster. >:(
http://amasci.com/freenrg/a-vectFE.html
http://amasci.com/tesla/tesceive.html
« Last Edit: 2010-03-01, 17:18:11 by giantkiller »
Yessir, I am going there next.
Will post new build test tonight. I have wound my antenna on a styrofoam core. I am curious about adding an electrostatic capacitor in the flux field. Also I have yet to charge up any styrofoam with a stun gun.
@GK
Combination Don Smith & Steven Mark coils.
This is an amalgamation of processes and configurations we have all seen. Nothing new here.
Also,
Standing wave model evident by the shape of the ship.
[youtube]http://www.youtube.com/watch?v=4RxLTKf58Ds&feature=player_embedded[/youtube]
Air LED
[youtube]http://www.youtube.com/watch?v=k0dMMEZW7M0[/youtube]
The quarter wave length of the coil resonance should of the core radius.
« Last Edit: 2010-03-19, 01:27:09 by giantkiller »
Wound the bucking toroid in 10 minutes, fired up the controller and lit the led in less 1 minute. Setup was a snap.
[youtube]http://www.youtube.com/watch?v=3cCkijcHEE0[/youtube]
Going back to the sport model with the dual pulse comp wave protocol with this tiny bucking toroid. I have a bigger one in the works on a 5" iron ring I bought from Ironhead. That one will have a bucking toroid inside another bucking toroid to the specs that Wattsup posted in OU.
I will start this one again. You can hear the bucking going on!
« Last Edit: 2010-03-19, 16:57:23 by giantkiller »
What if....
Two counter pulsed rings facing opposingly each produce the comp field. Use that effect to pulse the center bucking build that Wattsup is mentioning. The comp field is much higher in amplitude than the input voltage plus little current.
In reproducing Wattsup's BFpancake and bucking mag amp tests I have seen how easy it is to conceal the magamp in a small confine plus this little device, the bucking toroid, really does amplify. SM's bucking toroids are all the same unit. Obviously it is the real deal like Wattssup said.
Now with the opposing comp fields producing a greater magnetic force it produces a really compressed tight field between the 2 rings that snaps like electroctsatic discharge due to a very finite, and very pronounced, strong Bloch wall. This snap represents a high speed discharge and we know the reaction of coils to that. That snap becomes our striker that rings the bell. That bell emits frequencies to the out rings or compunds into the center secondary of the bucking toroid.
The bottom line is to produce a Bloch with a lot of magnetic pressure then use that strong force as our magnetic bias. The strong the Bloch wall then is the stronger that force equalling atomic matter or atomic/subatomic control.
And when we release the Excessive Bloch wall pressure? Mother nature takes over and puts the system back to equalibrium. And that can be read/captured also.
I now believe that the the Bloch wall compression, release, flipping is the bucking effect.
Add HV part of circuit and moved the fet push pull drivers to a better board. Applying this to the collector.
Testing with 1k, 3k, 4k freqs.
I need to diode bridge the HV sine to DC and raise the output voltage to 1500dc. I have uwave diodes good to 16kv/ .5amp(HVR-1)
I am integrating a Marx bank to supply the HV. Heading for 1500vdc for the collector.
With 1 single run collector I will have to search out a way to couple the collector energy off. A parallel run would have made it real easy. Want to maintain the dipole.
Will also add a cap to the collector for resonant LC attributes.
Diags for circuit.
On the doco list for additions are:
Add HV circuit
Make a full electronic schematic
Clarify the ground connections
Set up a testing protocol. Duty cycle not mentioned but will get this to 10 - 5 % ON time.
2 sets of tests exit: standard pulsing, induction, LC and anomolies.
http://www.overunity.com/index.php?topic=8227.msg251295#msg251295
« Last Edit: 2010-09-25, 00:04:20 by giantkiller »
I noticed an interesting pattern of discharge in the all the readings I have done:
The Tesla coil gets pumped up and produces multiple outward burts. Reports on functioning TPUs/coils report receiving lightning strikes.
The only difference is the direction of discharge.
Over the last 4 years I have stripped 9 monitors and have one sweet selection of HV caps, high wattage resistors, chokes, diodes, and transformers.
Also have dual scope probes rated at 4kv.
Building a Marx capacitor bank for 50kv upto 6a.
Have tried to used small NSTs for HVDC and they just don't cut it when rectified.
Using resistor ladder to subdivide current HV down to meter acceptable range.
The previous circuit is for standalone, self oscillating operation. I will meld the HV process into that circuit after the field jacking tests.
The plan is to apply up to 4kv on the collector at low current and modulate that field with adjustable DCV on the control coils. :)
Then tap off the collector. So far I have a 4kpf, 2kv cap inline with a 30kv diode.
https://www.gap-power.com/videos/videos.html
http://uvs-model.com/UVS%20on%20MM_experiment.htm
« Last Edit: 2010-10-05, 04:23:13 by giantkiller »
T.T.Brown applied high voltage to an aluminium plate which then registered lighter in weight.
He applied pulsing and this caused propulsion and velocity to a piece of mass.
Podkletnov removed the physical target then applied vectored pulsing which produced propulsion and acceleration to a magnetic density of mass but having no material properties. In other words no physical properties relating to a visible object. This magnetic mass then moved very quickly in a linear path.
Both of these men created a movable mass of high density.
T.T.Brown did not move a metal plate. It was deflected by the high density magnetic mass to a lower density area in space.
Steven Mark put this process in a ring. The Podkletnov process now becomes an inertial vortex. Time this correctly to spin the field. Place conductors in the travel path to collect the EMF.
The pulsing creates a higher density field in the high voltage, high density field of the bias. We also get fast pulse transistions which look like high density boundaries.
The plan is to use the high density flux field as a meduim for creation of rogue waves.
« Last Edit: 2010-10-06, 21:19:27 by giantkiller »
Have EC600 up and running.
Collector is powered at settings of 4kv, 5watts, 5ma with 100k ohm, 5watt in series.
Resistor temperature rises to +100 degrees Faren. Setup is finicky. Can't get to 4kv across coil unless resistor wattage is matched up with driving current.
Making adjustments to milliamps, volts and watts to find best setting for coil.
So far the EC600 looks bullet proof.
Next implication is to pulse the controls with 555 timer box as an initial setup. Then try dual pulse protocol under software control.
Can do:
GK,
Can't the EC600 be set to limit to 5mA? If so, you shouldn't need any resistance in series with the coil. Just use an output diode as ION mentioned.
Have HV turned off for the moment to get the resonant rise going.
Also this just in from Jason:
www.r-charge.com/Nov2010.html
« Last Edit: 2010-10-12, 03:26:08 by giantkiller »
Circuit setup for next test.
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-03-31, 17:30:01
