Careful Itsu, they will get hot as the output is around 4w or more depending on voltage input. Looks like the driver is fine, very clean, I think the problem is the mosfets or maybe (the 0.5 ohm 5w resistor if left out) @ 13.56MHZ. Other problem could be a very bad match on the output @ 13.65MHz. Most of these mosfets are good up to 30MHz it seems, so something around the mosfets is causing this, "SWR", check this with the swr meter you have at a lower power output (reduce the drain voltage). Part of your dummy load could be shot with the power being put into it before!! Not much left in the circuit to think about  Regads Mike
