I am almost in business I tried my cap idea by winding enamelled wire axially along a length of wire to form a capacitor, although my cap meter measured 100pf i could not get it to work properly so have given up on the cap idea for now. This means i need to buy some 200pf caps  Anyway i have etched 7 Marx modules , 2 driver boards and 2 output boards, i already built sometime ago the 2 900V switched psu's At the moment i have used 100pf caps and with a 47R resistor load the Marx boards do not work(The pulse doesnt get bigger with more modules GULP), as a temporary test i loaded with a 680K resistor and this verified they do work, once i get the caps i can try a coil. A photo of the finished boards some still need making up 3 Scope shots of the pulse across a 680K load resistor (Yellow Trace) with 1,2 and 3 modules stacked as you can see each Marx module does indeed add to the final output pulse amplitude.
