Hi Room, ion, 3D I have found some time on my own as my guests have gone to take in some nightlife in Valencia  Interesting topic Room, as some know I have been involved with radio since I was a teenager but for some years now my operating is only on 2mts (145Mhz) with a handheld for repeaters locally, I sort of lost interest and changed to new energies investigation, a big field. As ion knows, also being a HAM, antennas do bring in energy to a tuned circuit which is then amplified, it is their nature by design. Let us take a magnetic loop antenna which is a copper loop of "wire" where the two ends are connected to a capacitor so giving us an LC resonator. This is connected to a receiver/transmitter by a primary coil, smaller loop, near the opposite side to the capacitor, we now have a transformer. Well I won't go on about how an antenna works but if I am right the aether is the space between an AC capacitor, ionosphere and ground, which is running at the Earths frequency around 7-16Hz which is a very long wave and could be seen as DC in any one local spot if it was frozen like on your oscilloscope. So how can we extract energy from that wave! the antenna would be so big it would not be practicable, well we could apply a sort of modulation to that wave, treat it as a sub-harmonic of a wave we can deal with which is of a much higher frequency. SM was into audio modulation in a big way, it was his job. Sub harmonics can be a big problem in power distribution, they create huge reactive currents and voltages especially when switching  but in the audio business they are of great use in synthesizers. I have shown sub-harmonics in some tests of mine, I have shown the kicks when you get it just right and giving a higher db than the primary signal. I was looking in the beginning at the wrong end of the spectrum, it is not the higher harmonics to be looked at but the lower harmonics, those around 8Hz or so, that's 625 times low than "5kHz". IMO it is all to do with the higher frequencies we use being modulated by the earth's frequency when it is a lower harmonic of that higher frequency, extracting it using the moving charge within the electric field between a two-loop magnetic loop. The two loops are full loop solenoid coils with the capacitance between them. Regards Mike
« Last Edit: 2019-10-30, 17:50:53 by Centraflow »
