Here you go Chet: https://www.youtube.com/watch?v=pdCGlLgNNcQ(it's on my regular YouTube channel as 'Public'). The presumption has been no oscillations TK, unless it was refiring in some extraordinary manner from mains in the air or some such. But then, what exactly could be firing, there being no transistor. So, no delusions there, but interesting to witness something other than a resistor, labeled as such, doing resistor things for a long running time. Any coil is a resistor of course. Resistors and LED's have had me caught out a couple of times in the past...one time where a homebuilt synthesizer was switched off at the wall and the LED trundled on brightly for an hour or similar. It was merely draining from the large smoothing caps and whatnot of the (poorly designed) power supply. But, there indeed a simple resistor was doing the eye candy. Having limited the brightness in any case, it kept the LED at the same brightness for that unexpected run. With better design, it wouldn't have been a surprise, but the focus was on sound. A 10ohm was tried and does display similar traits. I'd never have thought that such a low value would do that. The scope does indeed show a flat trace. I guess we're all used to knowing that a small cap will deplete straight away with an LED across it. So, when that doesn't happen, it's all very exciting. However, no LED is running at top whack output in any circuit seen or experimented with so far, that I can determine. Factor in more efficient running with the right frequency for the LED itself and things do get interesting for efficiency. Tuning that frequency to a specific LED, from a specific manufacturer, is something I haven't seen done yet...anywhere.
