Hey Room can you upload any pix of your setup? Smudge the effect kind of resembles Donald Scotts Z pinch theory . Very interesting, just trying to get my head around types of coils and physical setup.
Hi Jimboot, Yes I can show some pics, the first one is a number of projects I have worked on, Gunderson gen., agent gates coil, my own rendition of the Bi-toroid, a 20KV multilayer capacitor, and several TPU coils and a circuit I designed and built to drive them with. There are a good number more projects I have done as well. The second picture is the latest TPU coils I have been working with. The red upper coil of the dual setup is the one with about 30 Turns of insulated iron wire .046 dia.. Wound on top of the iron is 4 coils of 29 Ga. magnet wire, approx. 400 turns each coil, with very small gaps between them (<1/16 inch). The lower coil is iron cored but uninsulated with no leads coming out. This coil seems to work the best for stirring the aether but no way to get anything out of the core, but this one I had 40 amp readings, at one point, on my clamp on meter just held at the center. These clamp on meter readings are very stable and do not jump around but do vary in magnitude at different locations around the coil. My clamp on is a mechanical (D'arsonval) movement not electronic like SM's was, so we are seeing the same anomaly with two different type meters. These are incomplete coils for testing purposes, finished ones will have another set of coils on top of the first four for transformer action which will then be rectified and used to drive the Kick generator which will then feed pulses to the core winding, upon exiting the core winding they will be fed through a single diode to a capacitor where the output will then be taken from. The green coil is my latest and is not finished yet, this coil has a insulated stranded copper core with insulated iron wire wrapped around the copper, one layer all the way around to provide the iron part of the core. The idea was to try and isolate the copper core from the transformer effects while still having a iron core. The kick pulses would be fed to the copper core and the iron would not be used for and output of any kind, just trying to move my way down the road on my own. Hope this helps you. Cheers Room
"Whatever our resources of primary energy may be in the future, we must, to be rational, obtain it without consumption of any material" Nicola Tesla
"When bad men combine, the good must associate; else they will fall one by one, an unpitied sacrifice in a contemptible struggle." Edmund Burke
