2025-05-13, 15:45:07
Author Topic: G6 Self powering coil  (Read 2691 times)
 I came across this youtube set of vids recently by IST. He does not post any more as far as I know.
https://www.youtube.com/watch?v=8cGisPr6Eq8
https://www.youtube.com/watch?v=CBaE2rVuQ1k
The principle appears to be creating an accelerator coil and pick up coils plus a starter coil on the
same toroid.
The effect is that for each pulse of the device, the accelerator coil makes 4 orbits compared to the other coils.
There has been some corroboration of this effect on overunity.com  by
N Ramaswami from India:
http://www.overunity.com/12794/re-inventing-the-wheel-part1-clemente_figuera-the-infinite-energy-machine/msg445856/#new
He used the principle of an 8-fillar  coil in series with an ordinary coil thus having a similar acceleration effect.
I don't know what to make of this effect.
Anyone with any experience of this??
King
I have to say Most here [older members] are quite familiar
with innovation station  ist
some luv him.... some luv to hate him
I like him .  and his zeal....
I have a contact somewhere if you want to replicate some of his work??
let me know.
Anyone who claims COP of 8 in an electrical device should be able to self-loop the system quite easily. If they cannot ... perhaps they do not have an OU COP ratio at all.
I have said more than once that if you show me a system with electrical inputs and outputs that _actually_ makes a COP greater than 1.3 to 1, I can show you how to self-loop it. And so could just about any other competent EE, and many of the experimenters I see on this forum could do it as well.
I don't care in what form the inputs and outputs are, as long as they are electrical. High voltage, low voltage, high or low frequency, AC single or multiple phases, DC, whatever.... if you genuinely have at least 1.3 times greater energy out than you are putting in from all sources... I can make it run itself, or run another identical unit, etc.
But nobody has ever taken me up on this _guaranteed_ offer. I wonder why?      :'(
@TK
I used to think three were issues with looping many years ago but I changed my mind. That is my goal because when there is literally no known power source of any kind in a stand alone device then your the man. No need for debate or opinions... it works and I would be right and they are wrong...period.
If that should ever happen you can be sure most would be eating crow, lol.
There is one thing to mention when using LEDs for load - in BEMF mode they can consume much less power than you usually see in conventional setup.
With the videos shown I could not see it running of capacitors and until it will be shown at least as very economic circuit if can't be looped there would be no use of it...
Cheers!
I have shown an effect with corroboration from a different source.
The Indian source is pure amateur "have a go" type.
If you cannot see the similarities then there's nothing more to be done.
If you cannot see that this is stochastic mixing then there is nothing more
to be done.
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-05-13, 15:45:07
