Hello
I need advice how to run resistive heater made for 230VAC/2000W on pure DC from filter capacitor. I believe I should adapt DC voltage level so the power dissipation according to Ohms law will be the same 2000W, right ? Assuming I measured 28ohm of resistance of heater element then I need to compute from P(ower)=U^2/R and find U. Is that correct ? Now the problem is two fold : - first what would be the advantage to create DC square wave from this DC power using chopper circuit , and how to do it ? Do you know what voltage I should have in DC capacitor to chop it at 50hz and get the same 2000W on resistive heater ? - if I run resistive heater on pure DC how I could prevent dangers in case of heater element become broken inside heater tube and in contact with (copper) wall of heater ?
I'm building electric heater for my home , and collect important information before start.
Thanks in advance for any help
