Mike,
i tried your circuit, but other then lightning up a 6V/2W bulb with some difficulty, no abnormalities found up till now.
See video here: https://www.youtube.com/watch?v=gwwEVgFhThs&feature=youtu.be
Below screenshot is the signal on the gate (blue) and the drain (yellow).
Thanks, regards Itsu
Hi Itsu The circuit is a straight foreward buck boost but the timing is critical with the rotor. This is because the phasing is all important between rotor generation and coil release energy when the mosfet switches off (opens). All the energies need to add at the same time, so the switching of the mosfet is all very critical with the passing of the rotor. A means of changing the timing on the gate I think will show this, as you have shown playing with the brushes  You did check the coil directions? this is all important as it will work against you if you have it wrong, there are many different configurations, Brad showed 2 on one coil, here we have 2 coils so this is 4, then between the 2 coils all in relation to the rotor I think will make it more. There seems to be a very subtle effect when all is in the right phase, i think Brad was trying to show this without going into huge detail. We need to add and not subtract, as I have said, buck boost works, but here we have added input at a particular phase, get it together at the right time and it will take off  regards Mike
