Increase of electrical energy by means of absorption of Zero - Energy.http://www.overunityresearch.com/index.php?action=dlattach;topic=2469.0;attach=13892OK i dug out a coil i had for some time, not ideal as Arie uses a 16.5cm diameter winding 33cm long, but though i would give it a try I setup as per his diagram below with one exception i placed 2 off 10 Ohm resistors at the common point of the caps and used the centre point as my earth point with each end of each resistor feeding cap item 5 & 6, i used a fixed cap for item 5 which was 33pf and used my variable cap box for Item 6, my sig gen positive was connected to the coil near the Item 7 end and the other bifilar coil was open circuited that end also as per the diagram. I used 4 scope probes all connected to the same earth point my 2 resistors were commoned at. Yellow was across the sig gen resistor Cyan was across the variable cap end of the other resistor. Purple was connected to point A on the diagram or after the variable cap. Blue was connected to the sig gen + I then looked for the maximun increase in current across my 10 Ohm resistors to find the resonant frequency of the coil which turned out to be 439KHz. First thing that stood out was i could not adjust for a phase difference of 180 Degrees as asked for in the patent, although i did find other interesting frequency's i could do this at much higher frequency's than the resonant frequency. The other thing that can be noted is that the current in the open coil is greater than the current in my sig gen coil. Any ideas how i should set this up so i can start looking for excess energy. Peter
« Last Edit: 2015-03-29, 20:58:11 by Peterae »
