Update: Tried the double reeds on this one, with it having just 1x 500ohm coil depth rather than 4 deep. An idea, was to put 1 reed at 180 degrees to the other. That would perhaps limit or even mostly remove the drag toward the reed metals (not the rotation drag). Unfortunately I wasn't able to get any firing. One of those things that needs very patient micrometer by micrometer adjustment I think. Or, the magnets widths are too small, that could easily be the case. Next then, to bring back the MMG motor itself. I've always been impressed with the speed of rotation, given by Lidmotor's drive circuit. Resistance was turned up on the Base of the transistor until it no longer fired, with 120K working well on the CFL powering method. If it saves 1uA, it saves 1uA. The change will be to add pickup coils around the rotor. I remember that Lasersaber showed his EZ Spin, with 2 driving coils and the rest were pickups. It functioned well as a sort of motor Joule Thief. 6 coils will be added, as 2 banks of 3. The other, reed powered motor, will have its 8 coils in use as remote pickup coils for this new design. That'll give 1 powered, 1 return to the circuit, 14 pickup coils. A sweet sixteen
« Last Edit: 2015-02-22, 21:12:06 by Slider2732 »
