AC Quote:- This kind of device is what I call a sequential feed-forward design with a regeneration loop generally found midsection at lower voltages.
All energy in these devices is external as the "cosmic energy" if you will also occupy the space in between the physical material. Thus external and internal energy are inseparable as they are one and the same. It's important to understand that while these devices seem unbelievably complex they are simply machines.Yes, I personally think you are right but would add the energy from the Earth's dynamo which creates the magnetic field and gravity, which then affects the Magnetosphere which in turn is affected by the Sun, which then creates the ionosphere (Ionisation). The energy is all around us between the latter and the Earth, the waveguide cavity, interreact within that cavity and you can extract energy. If an electron leaves an atom, such as when a current flows from the end of one wire to the other when in a circuit, then another electron is being COLLECTED at the other end. While this is happening, work is being done, your light bulb is giving light and heat which then goes back into the GLOBAL Electric Circuit. EXTRACTING ENERGY FROM THE WHEELWORK OF NATURERead my quotes at the end of all my posts. 2021 is going to be interesting if we are not all killed off A happy new year for 2021 Regards Mike
