OK This test used a 100 OHM load, the 100 Ohm was metal film hopefully thats ok, the primary NIR was still 1 Ohm I will describe the setup first for you to check i understood correctly. My sig gen positive connected to one end of NIR i have my yellow probe either side of NIR, my cap connects to other end of NIR as does my other scope probe earth, so both scope probe earths are together, the other side of the cap connects to inductor and the other end of inductor connects to the earth of the sig gen and my green probe tip. Green chan is inverted, so green chan is across series LC and yellow probe across NIR I had to set my cap box to 16nF to obtain a frequency of approx 771khz where i could adjust to get the phases of current and voltage to align. So first shot is green Voltage across LC and yellow across 1 Ohm NIR res 771khzpriyeli-greenv Then i dosconnected the green chan leaving the yellow across the 1 Ohm primary NIR resistor and connected the green across the 100 Ohm load which gives the second shot sec100ohmload771khzgreenloadyellowcur So Green is across 100 Ohm load and yellow the primary current. PS i had the load probe wrong way hence phase inversion. Not crunched any numbers yet, if i get a chance i will append the results  EDIT green 228mv yellow 52.9 Pin=12.0612mw Pout = V^2 / R Pout = 7.3mW Ok i was right to use V^2/R for Pout because if it's I^2*R then i have a Pout of 73Watts LOL and my little resistance should have been glowing red. Tomorrow night i need to try some higher resistance loads as a 1OHM load gave me Pout = 121uw Pin = 12mw
« Last Edit: 2015-02-19, 22:19:52 by Peterae »
