Thanks Smudge Tonight i really wanted to work out if any of my equipment is in calibration. I have 2 scopes a mains Owon 20MHz scope and the 200MHz Hantek DSO laptop powered i have been using up to now, i prefer the hantek as it is isolated by battery power. I have suspected my owon was out of calibration because it has a 5V Squarewave gen built in and when i hook that up i get 5.2V Pk-pk. So tonight i tried using first the Hantek and then the Owon I changed my NIR to a 10 Ohm carbon film and selected the 10 Ohm using my precision LCR meter for almost exactly 10 Ohm My load is measuring 516 Ohm and will use this for a while. I tried the subtraction method and it works pretty good now my current waveform is larger but i am still hesitant because of the 2 digit limitation. anyway i got 2 totally different results using the hantek & owon, i used just 1 probe to measure each variable Hantek 1 probe to measure each variable 500KHz 20nF I=636mv LCV=1.03 Load=5.75 Pin=65.51 Pout=64.07 COP=0.978 Using Owon 500KHz 20nF I=837.1mv LCV=1.202 Load=6.210 Pin=100.6mw Pout=74.7 COP=0.7423 So i then though how can i tell how in calibration each scope is, so i then set my signal generator to 50Hz and put a dvm on it to read DVM 7.33V and the 2 scopes read as follows Owon 7.414V RMS Hantek DSO 7.03V So it looks like the Owon is fairly close and it does 3 decimal places, so it looks like i now need to start the tests again using the owon. I will do all the frequency's again to look for a COP peak and then go from there. I need a new scope really
« Last Edit: 2015-02-26, 18:01:47 by Peterae »
