It reads as 49ohms for the inner 1000, 98ohms for the outer. Nothing happened with it either when tried out haha, ah well. If I combine the 2 windings together and wind a 3rd winding of 1000 as the new second coil, then it will approximate the 157ohms (or so) that Brad measured on his dolphin coil. Both would then be ballpark for running at the correct ohmage. Tedious indeed and the wish was to avoid that...so i'll try the 2 'dancing' coils next and probably get back to the winding afterward. The kick is given by the magnet being axial. It's N at one horizontal side, S on the other, rather than top and bottom. With the nub being in the middle of the concave surface that it sits on, the top can spin next to the coil, but never goes right over it. Such that, any interaction with the coil will cause the spin. It relates to the merry-go-round thought yesterday, in that to spin up one of those playground rides a person pushes the side framing in the direction of travel. Will take a measurement of the factory coil running the Top Secret and report back  . . It uses zero until the magnet comes close to the nub raised area in the middle and then uses up to 9mA while kicking it back out again with extra speed. The usage depends on the rotation speed, with 9mA being the peak recorded after several minutes of running. Meter used was a UNI-T 136B. I wonder, that seems very similar to the pendulum results, but far different to Brads reading for the dolphin. However, it would be in line if his gear records an average (?).
« Last Edit: 2015-01-30, 22:42:46 by Slider2732 »
