Some further tests, with a starting voltage of 25.19V (2x 12V batteries in series) on the drains. First the electret mic. test, which only reveals similar crackling sounds as emitting from the coil / magnets, so no howling. I tried with both coils (so with and without a center loop wire) and with 24V from the batteries as well as with the 41V from the PS (last one not on video). Then i tried to measure / show the current through 1 of the MOSFETs. It shows that the current flows the normal way from drain to source. Current controller was set to 5A/Div. and the voltage on the MOSFETs was reduced to 12.5V only (single battery), see screenshot 1. Screenshot 2 is both voltage (yellow) over drain / source and current through (green). Video here: https://www.youtube.com/watch?v=yyEAJqV4u7gNext i will use some different pickup probes to show the different signals. Itsu
« Last Edit: 2016-12-02, 21:15:45 by Itsu »
