Dear All.
Is this GL's Pelton wheel ?
Perhaps the reason behind it's water consumption is the simple fact that it leaks a little during operation ?
Admin: Converted that 6M file to 600k.
Yes I would say it is the Pelton wheel, it all seems to show that the real generator is this driven by a water pressure pump. Why is only one battery used for high current as the other only has a thin white wire connected, that would only do control power me thinks!! Is the belt driven motor from the pump infact a DC PM motor used as a generator as well? and run from the motor of the pressure pump? The third motor on the other side of the setup (nearly out of view), seems to be an AC motor as you can see the start cap shrouding, what is this for? possibility it is connected to another pump in the bottom of the tank as the pressure pump may need a minimum of 3psi of water pressure + volume to start with as in a karcher pump, but this seems big, 1/4hp? The investigation continues
