Sir,
I know you have studied Newman
can you comment? [mostly the water Pump]
NOT NOW I just wanted to put this here since I couldn't find a Newman thread!!
From user bolt at OU
AT giantkillers thread
Here
http://www.overunity.com/index.php?topic=8227.msg261927#new---------------------------------
Think about the Newman motor the "Giant Hotdog" He has converted a low voltage stack PP3 battery source into an ELF pulse through large inductor. The inductor the coil of the motor prevents current flowing so the power factor has been trashed it now like a PF almost 0
http://www.josephnewman.com/ yes i know he is as Loopy as a fruit cake but he worked this out decades ago!
"The energy machine is proof that the strength of the motor's magnetic field
is dependent upon the VOLTAGE --- NOT the CURRENT!
For the first time, Joseph Newman demonstrates the
energy machine that turns a 1,650-lb rotary and powers a
375-lb positive displacement pump using LESS THAN 20 WATTS!
In the video demonstration, the energy machine produces phenomenal
speed, torque, and continuously pumps water using LESS THAN 20 WATTS!"
In so doing now you have a machine which is basically KVARS due to current < very small on the batteries yet in circulation is > massive together with a circulating voltage of hundreds or thousands of volt from a few PP3 batteries. The central motor contact ARCS violent on switching.
WHERE does the machine gets its power from? The answer is a PF 0 trashed power factor conditions create large magnet forces from the ambient. So powerful in fact a magnet 12ft away hanging on a thread spins violently! This magnetic energy is converted to motor torque which provides more HP out then the power IN. This energy came from the ambient due to scaler PF 0 electrostatic field causing disruption to local electron spin. The misalignment is over corrected in the windings and iron cores where internal spin domain currents create a magnetic field as a result.
Anytime you have a moving charge you get a magnetic field.
So as Newman motor works so slow its the best visual example to see how to convert VARS to magnetic force then use that to create shaft power far in excess of the PP3 batteries.
As also per Don Smith teachings a HV source can become electrostatic (VARS) and THEN modulated to create a powerful alternating magnetic field. Use this FREE magnetic field for the source of your energy and NOT the EM fields. Alike his 1 to 4 copy Tesla tower device.
As TPU its the free magnetic rotational field which does all the work. The conditions to create a powerful magnetic field in rotation WITHOUT power banging fets is the key! Class C modulated electrostatic fields is the answer.
If the coils have a rotational 3D 2 layer magnetic force spinning it only takes another standard coil placed close by to make a generator. There is no EMP, no banging not in uS anyway only gentle switching. No CPU's and no 30 volt 20 amp lab PSU's required. OH shit that rules out just about EVERYTHING in the last 5+ years:)
