Still need to learn and testing how to and how much to inject of the HydrOxygas. The proper Air/Fuel ratio is the most important and critical part of this, there is no guess work allowed because of the extremely high flame-speed ignition and flammability of the HydrOxygas.
See below relevant info: Gasoline Vapor Concentration by Volume: The minimum concentration of a particular combustible gas or vapor necessary to support its combustion in air is defined as the Lower Explosive Limit (LEL) for that gas (examples: hydrogen, butane, propane, gasoline fumes, etc.). Below this level, the mixture is too “lean” to burn.
The maximum concentration of a gas or vapor that will burn in air is defined as the Upper Explosive Limit (UEL). At the UEL, is the most efficient – greatest explosion.
Beyond that, less oxygen is available for combustion. (and the excess gas, fumes, is wasted)
LEL for gasoline vapor: 1.2% UEL for gasoline vapor: 7.1%
LEL for Propane: 2.1% UEL for Propane: 9.5%
LEL for Hydrogen: 4.0% UEL for Hydrogen: 75.0%
Ref.: from Gas Data Book, 7th edition, copyright 2001 by Matheson Gas Products, and from Bulletin 627,
Flammability Characteristics of Combustible Gases and Vapors, Copyright 1965 by U.S.Department of the Interior, Bureau of Mines. All concentrations in percent by volume.
Greetings, Alex
